mysterious coolant loss, 99 sr5
been loosing a little coolant at a time. cant figure it out? no visible leaks, no choc milk oil, burns off a little white smoke at start up only, did the timing belt/ water pump about 40 k ago. it does have an oil leek from i guess the driver cam seal so im going to do the timing belt job again. no misfires or codes. any suggestions where to look? could it be a slow head gasket leak or a cracked head? how would you diagnose that. had a mechanic pressure test it too...nada!
