Originally Posted by djs239g
..Had the same issue with my 2010 SR5 T4R brake light…only on driver’s side.
The ‘Stop’ fuse under the hood and the bulb itself were both good.
All I did was wiggle the blue wire on the 6-wire small harness and now the brake light is working. If it goes out again I will try some dielectric grease on the contacts..saw that stuff when I bought new brake bulbs (that I didn’t need) at AutoZone.
…so a big thank you to whoever posted the tip about wiggling the small blue harness wire!
My 2010 RX350 had a similar issue with the daytime running lights. they would go on and then off and I couldnt figure out why. first drivers light then passenger. wiggling the wires solved the problem so I bought new plugs and cut the old ones off and replaced. now they are working fine. I wonder if after a while the wires get strained or stiff or corroded and don't make good contact in the connector. I would say thats the first non wear and tear item I had to replaced on that vehicle in 16 years ha
