View Single Post
Old 07-20-2026, 08:46 PM
hearno's Avatar
hearno hearno is offline
hearno is on a distinguished road
hearno's Avatar
Originally Posted by rpm5099 View Post
Wow, ok. I had already had my evaporator and condenser replaced, so it sounds like you did have a different problem. I'm surprised modifying the evaporator temperature reading made a difference at all with a blocked condenser, that's why I thought you were on the right track. I probably should have mentioned that you want to rule out restrictions in the system before going this route, but I guess at the end of the day you now have a way of making your A/C ice cold in the summer when you aren't worried about it icing up. Could be that I just have a drifting evap temperature sensor, but it never got very cold even with the previous evaporator and I would hope the new unit came with a new sensor (the one thing I did not do myself, was just too busy at the time).
I mentioned it in my original post but I probably should have called it out more directly - if you jumper that evap temp sensor with a 2kΩ resistor and the A/C goes from being coolish 55F to blasting ice cold air then your A/C is mechanically sound and the evap sensor is a potential culprit.
Glad you got it worked out!
Hey, saw you were here a month ago. Tried to send you a pm but it wouldn't go through. You able to check back in on this post?
2014 Trail
A mild build She gone... sad face.
2001 Limited 4x4
hearno is offline   Reply With QuoteReply With Quote
