Originally Posted by DanDel
I am new to this forum. I have been dealing with misfire error codes. I have narrowed it down to one injector, but here in Canada it is $250 for 1 fuel injector, so I bought a set on amazon that appeared identical to the 4-hole grey ones with the side hole. They just arrived today, but without opening up the bag, it seems that the side-holes (vacuum assist?) do not go completely through... will this mess everything up if my original set has the side-holes? Just wondering if anyone has had any experience with these issues.
I would only trust those Amazon injectors enough to throw them in the trash... You can either have your stock ones cleaned and flow tested or get a refurbed set of injectors from Motorwest. The Motorwest injectors are from a newer Toyota that flow the same and have the same air assist, but are Denso instead of Aisin.
Just a moment...
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
