Originally Posted by blcktpgsr
Great tip, I took my starter out in the same fashion, except I completely removed the upper part of the dipstick and just manipulate around the bottom. I also disconnected the sway bar and undo the fitting that goes onto the steering rack.
You can't fully remove the dip stick unless you drop the pan(it's welded to it) I'm sure you knew bein under there though. I didn't undo the fitting just because the way I had it situated I needed 1/8 of an inch to clear the starter terminal. Pushed it down twisted the sway bar up and slipped it clean out. Install ticked me off because I just put it straight in without touching anything! Haha
