Old 07-18-2019, 02:29 PM #1
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
When do you need to extend the rear bumps/sway links?
I planned on running without the front swaybar while keeping the rear as I heard this is good enough as the sway isn't extreme and the rear bar doesn't limit flex much.
But, when do I need to extend links or bumps?
Old 07-19-2019, 06:24 PM #2
jross20's Avatar
jross20's Avatar
Smile
Shameless bump in th name of learning?
Old 07-22-2019, 08:33 AM #3
Serge627's Avatar
Serge627 Serge627 is offline
Serge627 is on a distinguished road
Serge627's Avatar
You want your sway bar to remain parallel to the ground. So with a lift and stock end links it will cause your sway bar to angle down. You then need to extend the end links to get the sway bar back to parallel.
Serge627 is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 08:58 AM #4
jross20's Avatar
jross20's Avatar
Okay gotcha, so I take it was in the amount of lift you want to increase the link length? Is it as simple as for every inch of lift you add an inch to the link?
Old 07-25-2019, 08:11 AM #5
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
Normally once someone completes a suspension lift (on average, 3"), you extend your sway bar end links by about an inch proportionately to keep the bars level. The easiest way to do that is buy new, or move your front links to the rear and buy 2nd gen rear links for the front. This gives you the length you need and you can normally get away with suitable aftermarket replacements. I went proforged on mine and they have been holding up nicely. Any more lift, and you might want to look at buying adjustable ones, and if you are within an inch of stock height, I wouldn't worry about it. Hope this helps!
"Bumble" '17 Lim w/ IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx on 35s
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 01:55 PM #6
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a splendid one to behold MStudt is a splendid one to behold MStudt is a splendid one to behold MStudt is a splendid one to behold MStudt is a splendid one to behold MStudt is a splendid one to behold
official vendor
MStudt's Avatar
I'll give a little advise, and it starts with NOT making your sway bar level with the ground. If you do this on the rear you lower control arms will make contact with your sway bar/sway bar links. You want your sway bar to be parallel with your lower control arm. Or, just slightly up from it, but not level with the ground.
Once you lift you'll want to get longer links. This is simply to get your sway back to it's intended position. You can use 3rd front links on the rear, and 2nd Gen links on the front. This will give you the added length, but will not increase the strength. If you're looking for added strength you should look into the links below.
MStudt is offline   Reply With QuoteReply With Quote
bar , extend , extreme , links , rear
Rear links and hydro bumps..... GSD_LOVER 5th gen T4Rs 1 04-21-2021 12:21 AM
Rear sway bar end links WHT003RZM 5th gen T4Rs 1 12-08-2016 04:17 AM
Front sway bar removal and extended rear sway bar links. morphious 4th Gen T4Rs 25 11-29-2015 01:36 PM
When to extend sway bar links? Tooltime19 4th Gen T4Rs 7 09-21-2015 02:29 PM
Rear sway bar end links? Crashnrondo 3rd gen T4Rs 18 02-01-2013 08:13 PM
