03-04-2012, 03:11 PM
Gas guage???
Does anyone else's gas guage drop quickly after a fillup? Im still getting used to this 4runner, but ive noticed my guage drops to 3/4s after 40 miles of driving. That seems awfly odd to me!
I hand calculated my first tank and figured i got 15.9 which is dissappointing to say the least. I can almost get that out of my Dodge Ram Crew Cab which is a pig! Time to check the plugs and maybe chnage the fuel filter i guess??
Anyone on the guage though? Is that normal??
2017 SR5 4x4
Eibach Pro Truck Shocks
Wheelers T1 front coils (made by Eibach) OME 2895E rear coils
Good for 2.5” front and 2” rear - Wildpeak AT3 275s
03-04-2012, 03:12 PM
Yes normal. Mine does the same. The gauge is more a rough estimate to me. I used the trip counter instead.
03-04-2012, 03:15 PM
The gauge is known to be inaccurate on these things. Gas mileage is all over the board though. I only get about 15.3 and I'm stock. Others say they're getting over 20. Absolutely all my maintenance is up to date too and I really don't drive it hard at all. I have no idea why there is such a wide range with the MPG's on these things.
03-04-2012, 03:18 PM
Thx guys makes sense, hopefully i can squeak some more mpg out of her
2017 SR5 4x4
03-04-2012, 03:26 PM
I get around 18.5 mpg, much to PBR's dismay. As I said before, I don't drive very calmly.
03-04-2012, 03:46 PM
I was getting about 13.8 and then after seafoaming I get just over 15. Sometimes it stays high, other times it drops quickly. I just figure around 200 or so miles per tank and I'm good.
2WD 2005 SR5
03-04-2012, 03:54 PM
I been getting a little over 300 miles on my last few tanks with a mix of highway/city driving. But this time around, I'm at a quarter left and I only have about 240 miles on my trip counter. I doubt I will make it to 300 with this tank. Getting high teens for mpg's is better than I expected though.
With my gauge, it tends to drop slower when its full and when it gets under half it drops super fast. Especially yesterday when I went up into the city (Los Angeles) where there is way more stop and go traffic.
01 4runner Sport
03-04-2012, 05:50 PM
I average around 230-240 miles a tank when the light comes on, this is 50% city 50% highway.
[1997 Toyota 4runner SR5 4x2 3.4L V6 @ 176,000k miles]
5000k HID's DDM kit. FOG lights. Reverse light mod.
2.5" Spacer front 890 rear coils. 31" BFG A/T KO's Airaid Drop in filter Deckplate mod
NEW [2010 Toyota Tacoma Double Cab Prerunner TRD Sport fully loaded 2WD]
03-04-2012, 08:31 PM
My gauge only reads correctly when the AC is on. Go figure.
03-04-2012, 09:11 PM
These things have gas gauges?
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
03-04-2012, 10:30 PM
That's what mine does. I average 17 combined with 31's
2000 2.7L 4Runner 185K Millennium Silver, BFG All Terrain, T/A KO 31x10.50/15, Scanguage II, Front D-Rings, Full Weathertech, 15% Front Tint, 6500K HID
03-04-2012, 10:36 PM
the readers in the tanks are bad. and the part is discontinued.... and to get it fixed its $400 because everything from the tank to the dash is replaced, or salvage one. i read mine as 220 miles is cutting it very close.
4Runner:1999 4WD 5VZ-FE SR5 5 spd man. E-locker, 4.56 gears, deckplate mod, gray wire mod, fog light mod,
12v mod, Skyjacker 2.5" block lift kit F&B, 2" BL, OME 891, Rola Vortex basket w/ extension, Hi-Lift jack, shovel,
chains, 23,000 lb recovery strap, 1st gen roll bar, 2nd gen tire carrier, 285/70/17 Hankook Dynapro ATM,
moto metal rims, 6 3.5x6", 4 hella 500 lights, HID 10,000k 35w
03-04-2012, 11:27 PM
Mine did the same, until i drove it NEARLY completely empty. My light would come on around 200 miles trip and I could drive 80+ miles with the light on. Ever since then my gauge seems to be a lil more accurate.
2000 Limited:250K, Icon 2.5 fronts, Toytec Superflex rears/Bilstein 5100's, Yokohama Geolander AT 285/75/16, diff drop.
03-05-2012, 12:07 AM
I was wondering the same thing when I got mine last month. 1st tank only got 225 or so miles before the light came on and I averaged 15.9 mpg. However I only filled it with 14.7 gallons after that. The manual claims 18.5 gallon tank. So the next tank the light came on around 230ish and I decided to push it more. I went to 265 miles and still only put in ~15.5 gallons. This time I got 16.7 mpg but I did change the oil and put more air in the tires.
So I take it the light comes on way to early and I can safely go another ~40 miles after it does, I'm sure I could push it to another 60 or so miles after the light, but don't want to risk it.
This was all probably a 60/40 split of city/highway driving.
'14 Trail Super White|Nav|Tint|EnTune| Toytec BOSS Kit|Konig Countersteer Type X Matte Bronze 17x8"|Cooper Discoverer ST Maxx 255/80/17|SPC Light Racing UCA's|WeatherTech| 4300K HID's|Valentine 1|White Knuckle Offroad Sliders|GOBI Stealth
Build & Photo Thread
03-05-2012, 02:12 PM
Yup
Best bet is investing in a scan gauge like the ultragauge. It takes some setting up and such but its far more accurate.
