Old 05-10-2012, 04:22 PM #1
Markjr's Avatar
Markjr Markjr is offline
Markjr is on a distinguished road
Markjr's Avatar
No start or click. No power to starter relay!???
As described no start turn or click when I turn the key over. Tested the battery which is good, cleaned connections, and tested the big wire going to the starter with the meter and its getting power. tested the relay when the key was turned all the way and there was no power getting to it. Any ideas, iv been researching/trial and error for two days now.
1997 SR5 3.4L 4x4 5speed manual. Flipped this exact truck in Feb. 2010 so I bought another one
Markjr is offline   Reply With QuoteReply With Quote
Old 05-10-2012, 07:20 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Ever replaced the starter contacts?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 05-10-2012, 10:26 PM #3
Markjr's Avatar
Markjr's Avatar
Well, got it to work. We tested the relay with some wire and the battery so we knew that was fine, then tested the starter the same way and that worked. So we tried looking under the dash and started unplugging and plugging things in and out and eventually it worked. Not exactly happy that we didnt find the problem but glad its fixed...for now
Old 06-27-2012, 05:14 PM #4
richbob richbob is offline
richbob is on a distinguished road
Similar Problem
This has happened twice, now, so I don't want to ignore it: when I turn the key to the starter, everything goes out - it's like I disconnected the battery. I can jiggle the ground, and everything eventually comes back on.
I know the battery is good. The connectors at the terminals were corroded, so I change them to after-market; but they seem to be connected ok. I didn't want to remove the entire ground wire, as it seems to be wrapped in the harness; so I cut it, peeled the insulation back, and attached it to the connector. It appears to be a good connection, but, as I said, I can jiggle it, and the power comes back on.
If the cable is my problem, how hard is it to replace the ground cable?
richbob is offline   Reply With QuoteReply With Quote
Old 08-17-2012, 07:42 PM #5
Gospinn Gospinn is offline
Gospinn is on a distinguished road
Did you fix the problem...im having similar issue?
Gospinn is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 06:55 PM #6
Jimci Jimci is offline
Jimci is on a distinguished road
Did you ever figure out the issue. I’m having a similar problem. Gen 3 99. Was having intermittent issues starting. If I turned key no start no click. If I continued to hold the key in start position for several seconds would eventually start. Then that would no longer work and no start no click. Had the battery tested and they said it was OK. Did some troubleshooting and tested the starter relay, seemed to be working. Replaced the starter, still no start no click no dash lights, accessories (wipers turn signals radio) won’t power on when the key is turned and can’t move the AT shift lever. Can move the shift lever when I push the release button. Suddenly started and everything worked. Turned it on and off 3 or 4 times no problems. Took it for a test drive turned it off and started back up. Left it alone for an hour and no start no power again. Figured it may be an intermittent ignition switch so replaced it. No luck. I’m out of ideas except for neutral safety switch but would that cause no dash lights and no accessory power? Anyone have any ideas. I’d appreciate any help
Jimci is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 07:01 PM #7
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What did you replace the ignition switch with? As I had the issue with the starter just like that. I replace the ignition connector and was good to go.
Did you have dash lights issues before the ignition contacts changed. If not, I really suspect the replacement ignition contacts you put in is defective.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 02-25-2020, 03:17 PM #8
SR5_4Runner SR5_4Runner is offline
SR5_4Runner is on a distinguished road
Was this resolved? If so how was it fixed?
SR5_4Runner is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 12:38 AM #9
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
I am having the same problem starting my 1996 4 runner. No clicks or grinding of the starter motor when I turn the key. Total silence. instrument panel does light up. New battery, Good battery connections.
Stumped.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 06:27 PM #10
phx_4Runner's Avatar
phx_4Runner phx_4Runner is offline
phx_4Runner is on a distinguished road
Check the AM1 40A cartridge fuse under the hood.
Sometimes this fuse will blow, but the blown link will sometimes make contact. Easy/cheap fix.
phx_4Runner is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 08:03 AM #11
Do you have 12v on the starters small wire with the key in start position?
Old 06-29-2020, 10:32 AM #12
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
I had a similar issue but never resolved and never came back;
No Power To Starter Relay
Wedgy is offline   Reply With QuoteReply With Quote
Starter Relay Footofgod Classic T4Rs 11 11-12-2023 02:09 PM
Won't start - one click Bugsy 3rd gen T4Rs 29 02-25-2020 03:18 PM
No start issue, possibly starter relay giro 3rd gen T4Rs 10 12-28-2015 06:44 PM
Need starter relay 86 2.2re gman007 Classic T4Rs 0 01-08-2011 10:52 AM
Starter Click, Click, Click. Jump starts immediately??? daugherty83 3rd gen T4Rs 17 09-18-2009 03:46 AM
