Weird Problem
Champ1415
My passenger, rear windows and back window will not roll down. I know what u guys are gonna say this guy is a moron cause Its just a fuse. All fuses check out none blown. So any ideas.
I took the door panel off the other day. Put it all back together and tested the windows. Could only get the driver side to work, even on the other switches! Thinking o totally effed something up I pull the switch panel and clean all connections. Plug it back in, no luck. Only then did I realize I had the window lock clicked in. :banghead: nuts!
