Old 05-20-2012, 09:01 PM #1
mmml4's Avatar
mmml4 mmml4 is offline
mmml4 is on a distinguished road
mmml4's Avatar
Power Steering Pump Rebuild 5VZ-FE
Here is how I rebuilt my power steering for $21.00.
Seal kit from PSkits.com - Power Steering Rebuild Kits for Pumps and Racks $14.00 for the kit and $7.00 for shipping. It take about 10 minutes to completely tear the pump down.
The tools I used,
The pump removed from my 4runner,
Removed the pulley and you can see the shaft seal,
Removed the reservoir,
Removed the mounting bracket,
There is an o-ring at the base os the reservoir that will be replaced.
Removing the rear housing,
This piece is the side plate, it has two o-rings and a wave washer.
Here is the rotor assembly,
More to come
99 4runner SR5 3.4 auto, in the rebuild/build process
2wd to 4wd, SAS, 80 series LC axles and transmission
My Build, http://www.toyota-4runner.org/3rd-ge...ild-build.html____________________________________________
"The significant problems we face cannot be solved by the level of thinking that created them" Albert Einstein
mmml4 is offline   Reply With QuoteReply With Quote
Old 05-20-2012, 11:08 PM #2
Jungoes's Avatar
Jungoes Jungoes is offline
Jungoes is on a distinguished road
Jungoes's Avatar
Thanks for posting this up I've been waiting for your post since you mentioned it earlier. So are there any checks to make on this type of Pump (rotary vane Pump)? or is the repair mainly for leaks on the seals?
If possible can you take some shots of the vane assembly out of the housing?
Thanks for sharing, working on anything and taking shots always slows the process down, but its great to share the info..looking forward to the rest
2000 Limited, 2021 SR5
Jungoes is offline   Reply With QuoteReply With Quote
Old 05-21-2012, 07:15 AM #3
jonwilly2 jonwilly2 is offline
jonwilly2 is on a distinguished road
this is good to know, The cap on mine came off some how and I went through the mud pit a couple of times so i pulled the belt and been running arm power ever sense.
2000 4Runner SR5, Cold air intake, Auto, 2wd, 4.88, big dent
1995 4Runner SR5, E-locker, ATs, 5 speed 4x4
jonwilly2 is offline   Reply With QuoteReply With Quote
Old 05-21-2012, 11:14 AM #4
hugo2go's Avatar
hugo2go hugo2go is offline
hugo2go is on a distinguished road
hugo2go's Avatar
Thanks for the write-up.
Looks like a simple rebuild. I've done it on my Honda accord before, looks like the same rotor and vane concept.
Keep us posted on the results.
hugo2go is offline   Reply With QuoteReply With Quote
Old 05-21-2012, 11:32 AM #5
Qyota's Avatar
Qyota Qyota is offline
Qyota is on a distinguished road
Qyota's Avatar
Beast!!
Qyota is offline   Reply With QuoteReply With Quote
Old 05-21-2012, 07:23 PM #6
mmml4's Avatar
mmml4's Avatar
Cam ring and vane plates removed from rotor, also notice the snap ring that holds the rotor on the shaft, it is partly unseated so you can see it. I call myself checking the pics as I went but my eyes must be worse than I thought, sorry about the blury pics.
Front housing with the shaft seal removed,
Inspection instructions from the FSM,
Pump shaft to housing check, I used my digital calipers for this.
Vane to rotor check,
Vane plate check,
Random picts,
If anyone has any suggestions as to how this is arranged please feel free to speak up because I'm not real good at this. I will have to take some more picts and show how I prepared the parts for assembly.
Old 05-21-2012, 08:36 PM #7
quicksilvr's Avatar
quicksilvr quicksilvr is offline
quicksilvr is on a distinguished road
quicksilvr's Avatar
No, this is great man. It's just nice to see what you're up against before you do it the first time. There is always discovery that needs to be made on your own, just the fact that you took some pics and posted those specs from the FSM is helpful.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
quicksilvr is offline   Reply With QuoteReply With Quote
Old 01-12-2016, 11:16 PM #8
97t4r81's Avatar
97t4r81 97t4r81 is offline
Real Name: Keith
97t4r81 is on a distinguished road
97t4r81's Avatar
Real Name: Keith
Thanks for posting inspiration . I'll order kit soon, till then I hope my spare holds up. Just info I found out in my swap, the pump on my 98'( the squealer ) is electric. The pump from my 97'(parts truck) is vacuum powered. I just connected vac lines as they were and put in a t, as I moved an evap vac hose to the Back of intake. Took me 3 1/2 hours today and about two hours to remove the donor yesterday, thank Buddha for parts truck. I flushed ps system last week, after finding small leak from rack while doing rack bushings and inner tie rods. I filled with Lucas stop leak and prestone ps fluid. I ran the wheel lock to lock 5 times, topped. Then started and ran , lock to lock again 5 times, topped. Test drove no issue. 6 days later it starts to howl( like fluid starved)and vib in wheel. Fluid fine, a little over. I pulled belt yesterday and swapped it out today. I did the same fluid combo and fill routine this time. How important is Dexron3??I'm thinking the 166k pump didn't like that clean heavy fluid and/or a piece of who knows jammed it up. Any thoughts? The new old pump that I drove on for 4 years before installing it today worked fine and is working fine now. I've driven 30 miles on this swap.
Power Steering Pump Rebuild 5VZ-FE-image-jpg
97t4r81 is offline   Reply With QuoteReply With Quote
Old 08-30-2018, 03:16 AM #9
Rockdawg84's Avatar
Rockdawg84 Rockdawg84 is offline
Real Name: Sam
Rockdawg84 will become famous soon enough Rockdawg84 will become famous soon enough
Rockdawg84's Avatar
Real Name: Sam
Great thread. Just ordered the rebuild kit and will be doing this as soon as it arrives. This week my front seal blew out and I'm pretty sure that it had 230k on it all in AZ heat. Much better than $100 plus for a reman or over $300 for one from the dealer. I will report back on how it goes.
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
Rockdawg84 is offline   Reply With QuoteReply With Quote
Old 08-30-2018, 07:20 AM #10
nobb nobb is offline
nobb is on a distinguished road
Was a special tool needed to remove the pulley?
nobb is offline   Reply With QuoteReply With Quote
Old 01-22-2022, 09:03 PM #11
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Will this fix a whine issue? Got a NAPA reman unit ready to go in but i'm hearing a bunch of horror stories about the reman pumps being trash. Considering rebuilding my 230k OEM pump but I don't know if it will fix the problem i'm facing.
It always used to whine on cold in the morning but then later went away. 2 days ago the pump whined louder than usual and has not been quiet ever since. Cleaned the reservoir filter with 2 cans of brake cleaner and flushed the fluid but to no avail.
The 4Runner can sit but I want to make sure the PS system works at all time and I never feel comfortable using non-factory parts especially on a critical part like this.
2000 4Runner Limited 4x4 V6
Old 01-22-2022, 09:44 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I haven't had luck with aftermarket power steering pumps. Glad to know they can be rebuilt as it's probably make it like new again
. I have 2 or 3 spares for that nasty whine situation. Keep that screen on the bottom of the return line tank too. As they are known to clog up and starve the pump for fluid..
Rebuild Power Steering Pump willet43 Classic T4Rs 9 08-22-2017 10:03 AM
power steering pump RIrunner 3rd gen T4Rs 7 11-19-2009 10:18 AM
4runner power steering pump TechWrench General Discussions 0 06-30-2009 05:43 PM
Power Steering Pump lax815 Classic T4Rs 2 04-23-2008 08:48 AM
