Old 01-02-2022, 10:57 PM #31
Nova_GTS Nova_GTS is offline
Nova_GTS is on a distinguished road
Originally Posted by MountainBiker View Post
I went down the same road in 2015: tried the Gamiviti LandCruisier gear, and it wouldn't fit. I was able to find a donor gear from a used seat, and got it back together. I wish I would've measured the good gear while I had it off, and then I could provide a CAD model to you or Gamiviti. I guess I'll take the measurements of a good gear when it fails again!
BTW, prototype plastic molded parts are quite cheap these days. If it were me, I'd contact Gamiviti, but if they don't want to reverse engineer the gear, then I would do a short run of molded parts and sell them here. I wouldn't make any money on it, as this thread shows that this isn't as big of a problem as it is with the LC.
Since I replaced the gear in 2015 I tell everyone to not adjust the seats unless they have to! And as I'm the only one that drives the rig, the driver's seat very rarely gets moved.
I modeled it last night after I made this post.
(Or as good as I could on the actual teeth)
I was going to 3D print it in the next day or so to test. My idea was once I was sure my gear worked to actually print a female mold that the metal shaft fit into and cast the gear out of epoxy with a little bit of chopped glass in it.
If you have a contact to do a run I’d consider that route
Nova_GTS is offline   Reply With QuoteReply With Quote
Old 01-03-2022, 04:23 PM #32
MountainBiker MountainBiker is offline
MountainBiker is on a distinguished road
Sounds like a good plan!
Over-casting it onto the steel part with epoxy is probably a good approach. But if it goes wrong, how would you get the epoxy off of the steel to try it again?
Do you think that a molded part could be pressed on in the same way as Gamiviti does? Perhaps freezing the steel part (and heating the plastic part in boiling water) to get a partial cryo fit?
I'd quote it from these places. I'm sure there are others, but I've worked with all of these companies, in preferential order.
ProtoLabs
Fathom in Oakland, CA
Xometry
2000 Limited: Toytec Superflex, 255/85-16, Lil Skips gas tank skid, SaVage rear bumper and skids, BAMF Sliders
2006 SR5: FJC Coilovers +2", Toytec Superflex, 255/85-16
Sold: 2017 TRD OffRoad Prem (this rig was too nice for me!)
MountainBiker is offline   Reply With QuoteReply With Quote
Old 01-03-2022, 11:57 PM #33
I think it would be really hard to attach anything to the existing metal (other than by forming it around it); it has knurl marks like a barbell (you can see them if you look close). I can give heating and cooling a shot with the broken piece just for fun.
The reality is if I fail at construction then I’ll still be at square one. I think I’ll give it a shot and if it fails model the full thing as brass
Old 01-10-2022, 09:32 PM #34
Eureka!
Ok, I think I've figured it out, my prototype worked pretty well, the gear took power from the motor and moved the seat slide. Only issue was I didn't have the pitch quite right to manually adjust the seat with a 12mm wrench (overall, I'd consider it a win and "working"). Making a few tweaks and crossing my fingers it's perfect.
That being said if anyone needs any replaced, let me know. I'll probably put together a kit of 2 gears with instructions and post it up (I figured $30 shipped was a fair price to cover my costs).
Old 12-03-2022, 02:37 PM #35
dtederick65 dtederick65 is offline
dtederick65 is on a distinguished road
Thanks
Great post, did you came across any part numbers for the motor or gear???
dtederick65 is offline   Reply With QuoteReply With Quote
Old 12-07-2022, 07:24 PM #36
McWolffe McWolffe is offline
McWolffe is on a distinguished road
I need some replacements for my seats if you're actually making the gears.
McWolffe is offline   Reply With QuoteReply With Quote
Old 03-19-2023, 03:04 PM #37
Aurastyz Aurastyz is offline
Aurastyz is on a distinguished road
Can I adjust seats w/o Power?
Sorry for bumping an old thread- looked around the interwebs and the 99 Repair Manual- and couldn't find anything helpful.
How do I manually adjust seats w/o power? I have a 99 4Runner Limited and I just want to be able to access the 4 bolts.
Aurastyz is offline   Reply With QuoteReply With Quote
Old 03-19-2023, 04:40 PM #38
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
12 volt battery and alligator jump clips on the motor connector. Or plug the seat in and use the switches move the seats back and forth to pull the bolts.
Old 07-03-2023, 10:24 PM #39
DcPDX DcPDX is offline
DcPDX is on a distinguished road
I could use one. Thanks for putting this together!
DcPDX is offline   Reply With QuoteReply With Quote
Old 10-11-2023, 03:29 PM #40
WalkOn WalkOn is offline
WalkOn is on a distinguished road
tried turning the 22mm nut but no movement. any other manual method of moving the seat? my seat is only moving forward but not back
WalkOn is offline   Reply With QuoteReply With Quote
Old 10-11-2023, 04:18 PM #41
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
I don't know if the ones from a '99 Sienna will fit a '99 T4R but I bought a set from this site in July '21 and installed them. They were expensive but made the wife happy and that's what counts.
Here's my repair video: https://www.youtube.com/watch?si=JWr-nIH8DMP8bC9h&v=05xLfG01Q5E&feature=youtu.be
1999 - 2003 Forward/Backward Power Seat Adjustment Gear Kit | Two Men One Garage
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
power seat dyi , power seat failed , power seat problems , power seat repair , power seat stuck
Leather Seat repair Az4runnin 4th Gen T4Rs 2 05-12-2012 03:28 PM
Moving Driver's Seat biglar 3rd gen T4Rs 9 10-13-2009 04:16 PM
power antenna is stuck podzhopnik Classic T4Rs 3 06-04-2009 10:09 PM
Moving AC Power and Diff Lock Buttons aerochip 4th Gen T4Rs 19 04-09-2008 09:24 PM
Rocking/moving driver's seat? coolpop Problems & Warranty Issues 14 12-11-2003 08:54 PM
