Old 10-22-2003, 04:35 PM #1
Doric Doric is offline
Doric is an unknown quantity at this point
New member with 3rd gen 4Runner
Hi, all.
I'd been searching for a couple of years now for a meaningful bulletin board for other 4Runner owners; just found this place on Google.
I own a '96 SR5 4WD, in addition to a '92 Talon TSi AWD and an '03 Mazda Protege5. The P5 is the daily driver, the 4Runner is the family hauler, and the Talon is the part time toy/full time jackstand warrior.
I'm about to hit the search feature pretty hard, as I'm replacing the timing belt and water pump on the 4Runner this weekend for the first time. Any advice or links you can give me here would be greatly appreciated.
Thanks!
Doric is offline   Reply With QuoteReply With Quote
Old 10-22-2003, 07:18 PM #2
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Welcome to the forum. I have heard a lot of good things about the P5...good handling and a nice shape in my opinion.:rolling:
As for your questions, here is a link to answer both:
http://www.toy4x4.net/timing_belt/index.htm
Excellent write-up!! You will need a service manual and the special crank shaft pulley holding tool so you can remove the crank shaft pulley bolt and to retorque it.
While you're at it, consider replacing these:
1. Thermostat & Gasket
2. Cam Shaft Seals (X2)
3. Main Crank Seal
4. Radiator Hoses (upper/lower)
5. Accessory Belts - Alt, AC, Pwr Steering
6. Changing oil cooler hoses
Hope this helps.
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 10-22-2003, 07:31 PM #3
Thai's Avatar
Thai's Avatar
As for where to buy the stuff, I have heard good things about Bob Bridge at http://www.1sttoyotaparts.com/part_number.html You can order on-line too. Prices are usually 20-40 percent less than local dealer. It is advisable to have your VIN so they can ensure they get you the right parts.
From what i have been reading, use OEM parts only!
A list of discount Toyota parts dealer is at http://mywebpages.comcast.net/jonmar...s.htm#toyparts
Good luck.
2023 Lexus GX
Lets Go Brandon!
Old 10-22-2003, 11:00 PM #4
peter78's Avatar
peter78 peter78 is offline
Super Moderator
peter78 is on a distinguished road
Super Moderator
peter78's Avatar
Thai that is a good write up on replacing the belt. It looks to me the water pump is run by the timing belt, the same as my Acura and Honda. I remember someone at Edmunds saying the water pump was not run by the timing belt. Boy 217 ft/lbs of torque, that is a lot. I doubt my torque wrench goes that high.
2001 & 2004 Toyota 4Runner SR5 4X2
Both V6 and both Natural White
"Yeah, I like white and I like 4Runners"
peter78 is offline   Reply With QuoteReply With Quote
Old 10-23-2003, 10:40 AM #5
Very well-built for what I paid, and handles unbelievably well. Just enough utility to it to be useful. Got it out the door with A/T transmission for $14,100 with 3 miles on the odometer.
I just wish it wasn't so bloody slow, you know?
Very nice. That's exactly the kind of thing I've been searching for. I was starting to get scared that I'd be the one to make a write-up on my first 5VZ-FE timing belt swap. You just saved me a lot of trouble. Thanks.
3. Main Crank Seal
Hope this helps.
I bought the accessory belts because mine were cracking and worn. 80,000 miles on the truck.
Uh-oh. What are the horror stories? I bought a Bosch water pump and Dayco belts from Pep Boys. Figured they'd be good enough, as the 4Runner does Minivan Duty more than anything else.
Thanks for the help!
Old 10-23-2003, 04:40 PM #6
Thai's Avatar
Thai's Avatar
Make sure that you have the Toyota special tool to hold the crankshaft pulley while retorquing the bolt. If the bolt isn't tightened to the required (very high) torque, it'll eventually back out. The resulting pulley wobble will damage the keyway slot in the nose of the crankshaft. This would be very bad.
2023 Lexus GX
Lets Go Brandon!
Old 10-23-2003, 04:47 PM #7
Thai's Avatar
Thai's Avatar
I have just heard that since you're doing this every 60-80K miles, you should do it right the first time. I have no idea if the aftermarket stuff will be just as good.
good luck.
2023 Lexus GX
Lets Go Brandon!
Old 10-24-2003, 04:06 PM #8
...the special crank shaft pulley holding tool so you can remove the crank shaft pulley bolt and to retorque it.
I've called a couple of different places now and can't find anything fitting this description. Probably will need it.
Anyone have any ideas/part numbers, etc.? I'd be greatly appreciative.
Old 10-24-2003, 04:18 PM #9
I decided I'm going to make it instead. Anyone know the dimension between the centerpoints of the bolts needed to hold the crank pulley?
Old 10-24-2003, 05:27 PM #10
Thai's Avatar
Thai's Avatar
No idea.:dunno:
2023 Lexus GX
Lets Go Brandon!
Old 10-24-2003, 06:48 PM #11
That's OK. Thanks a lot for your help, Thai. I'll let everyone here know how it goes for me, and I'll be sure to post the answers to my own questions here for future members.
Old 09-25-2023, 10:36 PM #12
jwkiss0 jwkiss0 is offline
jwkiss0 is on a distinguished road
Wondering how the repair is coming. I’m heading down the very same road. Did you find the special tool?
jwkiss0 is offline   Reply With QuoteReply With Quote
Old 09-26-2023, 08:15 AM #13
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
20 years later and that person hasn't logged onto the forum since April 2007.
Old 09-26-2023, 08:34 AM #14
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I think this one wins for oldest thread revival. Holy cow! That is awesome! Lol
Old 09-26-2023, 08:53 AM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nope. It's not the oldest. The search Tapatalk doesn't always show everything. So I can see how easy this happens. Besides people complain when users don't search then they complain when they start a new thread. Uses can't win. ;)
Looking to buy a 3rd gen 4Runner, need opinions please. raydium 3rd gen T4Rs 7 09-28-2021 06:12 AM
bunch of 3rd Gen stuff for sale ChildrenOfBodom Classifieds - buy & sell (no commercial ads please) 15 06-05-2010 04:53 AM
Help!! 3rd gen 4runner vs Surf undercarriage blue4r 3rd gen T4Rs 1 05-22-2010 11:55 PM
4th gen. 18" wheels on 3rd gen. 4runner? Flzrider 3rd gen T4Rs 15 11-17-2007 02:45 AM
18" '07 4Runner wheels on a 3rd gen? GatorGreg 3rd gen T4Rs 10 11-13-2006 11:01 PM
