Old 07-28-2012, 08:06 AM #1
lcchik's Avatar
lcchik lcchik is offline
lcchik is on a distinguished road
lcchik's Avatar
Any way to tell if an engine has overheated?
I bought my 01 4Runner last October with 78K miles. A couple of months ago a rod broke while turning into a parking stall. Bought a 132K used engine from LQK with a 6 mos warranty. While taking apart the old motor, we noticed that it appeared that the water pump had leaked in the past. The timing belt looked new.
I wonder...could have the engine overheated (due to faulty water pump) with the PO leading to later rod failure? A mechanic I recently spoke to had this opinion.
When we replaced the water pump on the "new" LQK engine, it looks as if the water pump had failed on this engine (lots and lots of what appears to be dry foam around it). We are replacing just about everything...radiator w/hoses, timing belt, idlers, valve gaskets, cooler o rings, pcv valve, etc. while the engine is out.
Ok....so now I am paranoid. Could this "new" engine also have overheated? What can I check to see if it had possibly overheated? Anything else I can replace?
2001 4Runner SR5 4WD Thunder Cloud Metallic plus a "few" Land Cruisers
lcchik is offline   Reply With QuoteReply With Quote
Old 07-28-2012, 08:27 AM #2
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
There is now way of really knowing if it had ever over heated.
The LKQ warranty is solid though. Just document the fact that you have replaced the WP and TB. I would also take a picture of the old wp too.
You can check the overall condition of engine by doing a leak down check followed by a compression check.
FWIW, I don't believe that a broken rod would have any thing to do with over heating
My grandfather once told me "Never loan out your truck or your wife because a rod could be thrown in either one of them."
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 07-28-2012, 08:31 AM #3
lcchik's Avatar
lcchik's Avatar
very wise gramps!
Old 07-28-2012, 09:34 AM #4
white_n_slow's Avatar
white_n_slow white_n_slow is offline
white_n_slow is on a distinguished road
A broken rod is more likely the result of poor lubrication or horribly askew tuning (running lean). Seems like the head gaskets would go long before the internals gave out if the issue was just overheating. Either way, document everything just in case!
my $0.02
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
white_n_slow is offline   Reply With QuoteReply With Quote
Old 07-29-2012, 01:40 AM #5
lcchik's Avatar
lcchik's Avatar
Good to hear. I was impressed by the LKQ salvage yard - very organized and huge! The engine I received was very clean and a 6 mos warranty was better than most. Would definitely use them again, although I hope not to.
Originally Posted by white_n_slow View Post
A broken rod is more likely the result of poor lubrication or horribly askew tuning (running lean). Seems like the head gaskets would go long before the internals gave out if the issue was just overheating. Either way, document everything just in case.
Ok I am feeling less paranoid. Good to hear that both of you do not associate a broken rod with overheating. Perhaps I just got a bad engine. Lucky me.
Old 07-29-2012, 01:50 AM #6
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
not exactly what you're asking about..
but, was it making any noise? usually they'll knock pretty loud long before they break. they give plenty of warning..
also, a busted rod isnt related to overheating...
nevada is offline   Reply With QuoteReply With Quote
Old 07-29-2012, 10:24 PM #7
lcchik's Avatar
lcchik's Avatar
Nevada....absolutely no warning at all. Was turning into a parking stall, heard a loud bang when I stopped in the stall then the truck started shaking. Dash lit up...no noises at all...just shaking. Drove 15 miles to the dealership with still no knocking. Even the dealership was surprised how normal the engine sounded.
Although rare, I have read that these engines have thrown a rod at low speeds and or while turning. At least I can say the truck didn't leave me stranded!
Overheated in the 3.slow Jcalderon Classic T4Rs 7 07-12-2012 10:59 PM
4runner overheated... Atreyus 3rd gen T4Rs 25 04-16-2011 01:44 PM
Overheated (please help) superduty Classic T4Rs 2 09-21-2010 12:37 AM
My 4runner OVERHEATED.......AGAIN!! Mr Brewster Classic T4Rs 4 02-15-2009 04:57 AM
Just got 1992 T4R and got overheated... 4R_in_Uzb Problems & Warranty Issues 1 07-04-2007 01:44 AM
