Real Name: Joe
Real Name: Joe
Check the level when the atf is fully up to temp, then while parked move the shifter into each gear P-L for a sec or 2 with your foot on the brake and then back to P. Leave it running as you check the level, should be in the hot range at that point.
When I installed my cooler and flushed the trans, I made the mistake of checking it cold, and it wound up being below the hot range when hot. You want it to be in the correct range at operating temp.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
