Old 11-15-2012, 09:19 PM #1
Shorehunter99 Shorehunter99 is offline
Real Name: Justin
Shorehunter99 is on a distinguished road
Real Name: Justin
Tranny Fluid level question
About a week ago i installed a B & M supercooler on my 97. While i was at it i went ahead and dropped the pan, replaced the tranny filter and flushed the transmission. I had drained about 5 qts outta the tranny so i added 5 qts then flushed and refilled 1 qt at a time. Well i made sure the level on the dip stick was good and took it for a ride. After about 10 miles checked it again and i was reading cold. I added a lil here and there till it was in the hot range. All in all i had to add 1.5 qts to get it in range. Since then ive checked it cold and hot and this might sound weird but the dip stick reads high in the hot range when its cold and low in the cold range after i drive about 5+ miles. what the hell does this mean and is it normal? Its like its reading opposite of what it should. I dont wanna have too lil or too much fluid in the transmission. Thanks for all the help.
Shorehunter99 is offline   Reply With QuoteReply With Quote
Old 11-16-2012, 12:34 PM #2
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
Check the level when the atf is fully up to temp, then while parked move the shifter into each gear P-L for a sec or 2 with your foot on the brake and then back to P. Leave it running as you check the level, should be in the hot range at that point.
When I installed my cooler and flushed the trans, I made the mistake of checking it cold, and it wound up being below the hot range when hot. You want it to be in the correct range at operating temp.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 11-16-2012, 04:58 PM #3
Real Name: Justin
Real Name: Justin
Ok ill check it at operating temp again. Thanks.
transmission fluid level bcantrell Maintenance/Detailing 10 03-31-2020 02:35 PM
Tranny Fluid Question Bigmikelakers 3rd gen T4Rs 38 08-14-2012 10:20 PM
Should i change my tranny fluid? noob question but what do you old gearheads think:) 240m3srt 3rd gen T4Rs 7 04-15-2012 07:25 PM
Automatic Tranny Fluid Change Question Steve8v92 Classic T4Rs 0 01-07-2009 04:36 PM
3rd gen transmission fluid level question wm69 Maintenance/Detailing 8 11-19-2008 12:31 AM
