Old 02-05-2013, 12:59 AM #16
blizz86's Avatar
blizz86 blizz86 is offline
Real Name: Brian - 20
blizz86 is on a distinguished road
blizz86's Avatar
Nice shots man, arb is looking good.
Which projectors did you decide to go with again? I remember you posting on the GB thread.
2000 Limited 4x2 Build - OME lift // Tundra Brake Upgrade // Wet Okole // 265/70/16 Michelin X Radial LT2 // 3" FXR + 50 w Morimoto 5k // 1.25" Spidertraxx 4 corners
2012 SR5 4x4 [Magnetic Gray]: Stock suspension // OPOR TE sliders (trimmed rocker panels) // Husky Mudguards // CMG Roof Rack
blizz86 is offline   Reply With QuoteReply With Quote
Old 02-05-2013, 03:33 AM #17
tyr0981's Avatar
tyr0981 tyr0981 is offline
tyr0981 is on a distinguished road
tyr0981's Avatar
i was just trying to encourage people to get in on these bad ass projectors! i'm old school with the FXR2.0's. Still working great after ~3 years of service!
no suggestions on the hotter temperatures when bogging through the slushy snow eh? well i've been thinking replacing with an electric cooling fan might be good for her even before this incident today (the only getting warm incident I've ever had) i'm concerned enough i may just do it.....
tyr0981 is offline   Reply With QuoteReply With Quote
Old 02-05-2013, 03:38 AM #18
blizz86's Avatar
blizz86's Avatar
Lol i didn't even seen your question, i was too busy looking at pictures. Have you flushed the coolant recently? I've never had that experience, or any snow experience here in socal. But it would seem about right that it would heat up after not gaining traction, electric fans is a real possible fix or something might have gotten caught in the condensor/radiator?
Old 02-05-2013, 11:36 AM #19
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all
Real Name: Isaac
id go to an auto parts store, and buy a "T" fitting that allows you to hook up your garden hose to the cooling system, and flush your cooling system. basically you cut one of the coolant system hoses that run into the fire wall for your heater core. and you install the "T" valve(best to do it at its highest spot), and then use the hose clamps provided and put it all back together -if you need or want help doing this i can help. i pull the lower drain on the radiator and turn the hose on and start the truck, turn the heater on full, and let the system flush. i do this 3 or 4 times over a period of a week. then drain radiator and fill with straight coolant. there is enough water in the block that the 100% coolant in the radiator will fully mix with the water in a day or so to give you your mix of 60/40.
depending on what comes out of your cooling system or how well the flush works you might want to invest in a new radiator. i think they are only like $100 so its not a huge cost. i just replaced mine this past spring as i had a leak in the top core cap. -also not a bad time to install a external trans cooler
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
the great him is offline   Reply With QuoteReply With Quote
Old 02-05-2013, 03:33 PM #20
tyr0981's Avatar
tyr0981's Avatar
my radiator fluid tests good, it has been a couple of years since i replaced it... the radiator i replaced ~5 years ago (the top of it was leaking) like "the Kid" was talking about...
so what i'm taking away from this is it is NOT Normal to heat up like this... alright so i'll have to start poking and prodding......
Old 02-25-2013, 06:53 PM #21
tyr0981's Avatar
tyr0981's Avatar
oky doky, the B&M "super cooler" is installed! i attached an R1 Engine cooling fan to the back of it also (whoever recommended that, i thank you!) i was going to pull the transmission pan and clean up the filter also, but the cooler was such a pain in the ass that i called it quits, for fear of being too pissed off and screwing that up somehow.....
So the bottom part of my radiator shroud wasn't bolted to the radiator anymore, the plastic loop looks like it just broke on the end, so a giant washer is holding it in place now, hopefully that addresses the heating up when i was 'Snow Bogging' i'll have to put it to the test soon
any off road trips in the Portland / Vancouver area planned?
Old 03-03-2013, 07:54 PM #22
tyr0981's Avatar
tyr0981's Avatar
Deck-mod and ECT button / Rear Window button lights replaced!
Is it just me or does the deck mod make the throttle response seam allot faster?
i'll take a picture when the sun goes down so my perdy white lights can be seen
Old 03-03-2013, 10:50 PM #23
tyr0981's Avatar
tyr0981's Avatar
Next is the A/C button then maybe clean up the Dust and Dirt that I've been neglecting....
Old 12-08-2013, 08:46 PM #24
tyr0981's Avatar
tyr0981's Avatar
So the mysterious oil leak, was a cracked valve cover (Left side on the very back top bolt) so i couldn't see it leaking from there under the intake manifold.... 130$ later from Rockauto.com i have a shiny new Valve Cover that's not leaking.
Next non-repair project is a roof rack. I've been prowling the build threads and asking lots of questions (thanks to those that answered my nagging) and this weekend is the start of the build!! :
Perfect 45 degree angle!
and i tac-welded together a 'proof of concept' today:
The biggest challenge has been keeping everything at the proper angles, and vertical supports the correct length and tube notches equally deep (i'm just using an angle grinder). So the learning curve continues.... will have to disassemble this pictured test assembly to start welding the actual pieces soon! now beer-thirty & Kalbi marinated Steak!!
Or maybe some 10 Year old Bourbon....
Old 12-10-2013, 07:45 PM #25
tyr0981's Avatar
tyr0981's Avatar
An Afternoon of welding... my oh my lots of touch up work is needed....
Not going to do a full length rack because i don't think i need that much capacity... well i hope i don't at this point. Anybody want to try and sell me on needing a full length rack in the last minutes?
Ill4runner Build
Old 12-11-2013, 12:51 PM #26
Bandit Runner's Avatar
Bandit Runner Bandit Runner is offline
Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough
Ah, that takes me back. Lots of fun, isn't it? Looking good so far.
One of the reasons I went with a full length rack is that I wanted to put lights on the front of it, and I didn't want the lights behind the sunroof.
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
Bandit Runner is offline   Reply With QuoteReply With Quote
Old 12-11-2013, 08:01 PM #27
tyr0981's Avatar
tyr0981's Avatar
I can see how lights behind the sunroof would be annoying, the glare alone is reason enough. i'm going to put 2 lights on each side of the rack, facing at angles, back will be angled back and front angled forward, they are the "Tuff LED's" 27 watt's a piece, square, from Amazon, this is a picture of 1 light on: (borrowed image from the interweb)
Plenty of light for the sides and back i think, and i'll have 6 total, 2 on each side and 2 on the back, i already have 2 spot lights up front, with the FXR Projectors it gives the front A TON of light, so far i haven't needed more than that up front.
Ill4runner Build
Old 12-22-2013, 03:45 PM #28
tyr0981's Avatar
tyr0981's Avatar
Bottom section Nearly ALL WELDED! just need to wire, measure, cut, weld the top. Progress! And then start on the roof attachment, going to copy Soco's Mount
Ill4runner Build
Old 01-07-2014, 08:41 PM #29
tyr0981's Avatar
tyr0981's Avatar
Well after a wiring cluster-f**k, i pulled all the wires out, and continued assembly and will save the wiring until just before i'm ready for primer & paint, hopefully it'll go smoothly then because i won't be able to see what i'm doing at that stage of the assembly. I attached the top rails today! probably be awhile before i work on this again, need to find / fix a mysterious oil leak....
picture of today's progress:
Ill4runner Build
Old 01-24-2014, 09:40 PM #30
tyr0981's Avatar
tyr0981's Avatar
Well when it's too cold to paint outside / in the garage, into the dinning room!
Wiring was a *****! but got it done, all the lights are in hand, will be wired and installed as soon as paint is is done.
Ill4runner Build
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
The question: to build or not to build... zoski 3rd gen T4Rs 23 07-24-2012 12:50 AM
My SR5 Build Firefighter EMT 5th gen T4Rs 24 12-31-2011 11:38 PM
