01-13-2013, 09:09 PM
funny stuff happing here....
so put everything back together after the cb install a few days ago and noticed my clock wasn't working, figuring i had just forgotten to plug it in i pulled it all back apart, well i was right i had forgotten to plug it in, but upon pulling it all part i couldn't find the plug and just for the heck of it i plugged the rear window plug into the clock and the clock worked then i pulled the plug from the clock and put it into the rear window switch and that worked.....so i'm missing a plug somewhere and for the life of me i can't find it and what's even worse i'm not sure i'm looking for a braid coming from the front or the back now....anyone know where the clock plug runs from and where the rear hatch window pplug runs from?
'76 FJ40, '87 4runner, '98 LC 100, 99 4runner,'02 Tundra,'02 LX470,'08 Tacoma Dbl cab,'09 LC200, '16 Trail Premium. also 76 super beattle,'06 XR650L,'18 Triumph Scrambler-XE.
01-13-2013, 09:26 PM
I will pull my dash tomorrow and take some pics. I just had it all apart today to wire a switch for my power antenna. If I have time in the morning I will post some pictures for you. They are all bundled together though, so I think you should just pull it back apart and poke around with a nice bright flashlight and I'm sure it will present itself.
The 4Runner Show
01-13-2013, 09:34 PM
I recall the same issue when i did my cb. I was sure i was missing a plug and even now i think theres an open connector but everything works properly.
'99 Ltd 4x2
Some welders
01-13-2013, 10:01 PM
I remember there being an empty spot near the clock that you could plug the connector into. Idk why its there but some members were saying they had non functioning clocks and found that an issue. Worth a check
1996 Limited 4X4 Desert Dune, 140,000 miles, E-Locker
About to get a 5-Speed r150f!
I swear by your title I thought your were going to say you have had another tree fall on your 4runner.
I swear there are more connectors in the dash then are utilized.
01-13-2013, 10:20 PM
If I remember correctly all of those wires for the top connectors should lead to a them all being wrapped together, it comes from the right side. Just grab it and pull it out a little. I'm sure you'd find it. Plus a nice maglite might help.
00 4runner 3.4l 5-speed
Front 5100/Eibachs Rear 5125/LC 8wraps
In need of 35s
01-13-2013, 10:28 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
x2
I remember the first time I took my dash apart to put in a cd player. I put my clock plug into that un-needed spot and realized it didn't work. It took some research to figure the problem out.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
01-13-2013, 10:46 PM
Originally Posted by ARKRWLR
x2
this i what i did... i plugged it into the "dead spot" which actually looks like the back of the power window switch, but is actually nothing....how madding was that, i removed everything, stereo,climate control, ect , ect, thinking the radio pushed/pulled it back and down somewhere....typical guy thinking though, if there's a hole it needs a plug.....:
01-14-2013, 12:19 AM
how/where did you wire the switch for your power antenna?
01-14-2013, 12:59 AM
Real Name: Isaac
Real Name: Isaac
jason, we are never camping together, you are not plugging any of my holes...
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
01-14-2013, 01:03 AM
Ahhhhhhahaha you're too funny! Ya know what?? The factory actually did that ti mine. I bought it off the original owner and he said it had never worked since day one. And when I installed my cb I plugged it back into the clock and voila it works now!
In need of 35s
Laughed so hard I think I peed a little bit.
My Junk
01-14-2013, 01:14 AM
Awesome, I love when its a simple little fox like this. I had mine apart for a while while soldering my clock, and I couldn't figure out why my turn signals stopped working all of a sudden. Hazards weren't plugged in....:banghead:this reminds me, I still haven't soldered that clock...
Glad it was something simple though.
01-14-2013, 07:55 AM
I just cut the blue wire from the back of my after market radio and installed a switch inline. I can post a write up if you are interested.
The 4Runner Show
01-14-2013, 01:56 PM
I've been doing research on putting a mirror with compass and temperature read out in my 4Runner. From my reading and a look under my hood, 1999 4Runners came with a temp sensor. Could that be the extra plug? Do you guys have the climate control with the temp read out? Just a guess that I'll put out there.
