03-21-2013, 04:27 PM
Real Name: Steve
Real Name: Steve
Rattling sound only when accelerating
Hello --
I recently started experiencing a problem with my 2002 Toyota 4Runner (168k miles) where it is making a metallic rattling sound on acceleration. It literally stops when you let off the gas... but as soon as you so much as touch the gas it returns. It sounds like it's coming from the passenger side of the engine compartment. I have run 87 octane for as long as I've owned the truck and just filled up w/ 93 in the hope that it might help. The sound is still there.. albeit perhaps slightly less so.
The first time I noticed this was a month ago but it went away within a minute and hasn't come back until now... where it is constant.
How would you diagnose this / what would you guys recommend here? I'm not sure if this is called a "knock" or "pinging"... but it is very concerning!
Thanks in advance!
-Steve
2000 Toyota 4Runner Highlander Edition - Manual, 3.5” Lift, 17” TRD Pro rims, 32s - son's future 1st vehicle
2002 Toyota 4Runner Sport Edition - TRD SC, AEM FIC-6, 3.5” Lift, 17” Sequoia rims, 33s - toy
2013 Lexus LX570 - 22” rims - wife’s truck
03-21-2013, 09:44 PM
Baffle inside one of your cats?
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
03-21-2013, 09:57 PM
Real Name: Andy
Real Name: Andy
replace your catalytic convertor.... i just replaced my original muffler at 272,000 miles.... i can here my cat now.... next paycheck
"It's Captain Jack Sparrow!"
03-21-2013, 10:20 PM
I had a similar problem right after I bought my '02 TR4. I was probably around 70,000 miles at the time. It was a very light rattling, only on acceleration. After taking it back to them twice, they told me it was some kind of heat shield. They fixed it...for the time being. 160,000 miles later...the sound has returned! No more warranty, and I don't live near the dealership that fixed it the first time.
2000 4Runner Limited 4x4, 3" OME lift, 2nd Gen TRD supercharger. 282,000 miles - SOLD
2010 Jeep SRT8, 7.2 Arrington 440 stroker, 550 whp! - FOR SALE
2007 Jeep Wrangler Sahara...too much to list!!
2015 Ford F-250 Platinum Powerstroke 4X4
03-22-2013, 12:10 AM
Real Name: Steve
Real Name: Steve
Good ideas, guys! I will definitely try to get a better feel for where the sound is coming from exactly. Do you think it could be pinging / detonation? I am considering Seafoaming the engine {it has never been done} in the hope that this could help should it be pinging.
03-22-2013, 12:14 AM
Does it rattle when you step on the gas in neutral or just when it has a load?
236K miles
03-22-2013, 12:38 AM
Real Name: Instagram: briansd_97r
OP, based on your comments and those in this thread it could be any number of things and no clear way to determine what it is exactly ...
My money is on a leaky exhaust ... cheap welds break over time. I had a similar issue and it was a exhaust leak.
Take it to a muffler shop or Toyota place (not a dealer) for diagnosis. Don't just pull your cats based on this problem description.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
03-22-2013, 09:51 PM
Real Name: Steve
Real Name: Steve
On further inspection (my neighbor's ears while a step on the gas) it does not seem to be an internal engine issue but instead a rattling heat shield somewhere on the exhaust path. It does go silent when you let off the gas, but has a distinctively metallic sound. I am going to put the truck up on ramps and inspect the path back... I bet you guys are right that it's a bad weld along the way...
Thanks for the great advice here! I am relieved that it doesn't seem to be pinging/detonation. I'm also crossing my fingers that it isn't internal to one of the cats!
03-22-2013, 10:04 PM
the bolts on one of your heat shields probably rusted out. I had the exact same problem. It is a quick and easy fix, just put a new bolt on it.
2001 4Runner SR5
OME Lift 883/891/Comfort shocks/Toytec diff drop/ 1.5" rear lift spacers--BFG KM2's 255/85/16--B & M 70268--ScanGauge II--Uniden PRO520xl--JVC Arsenel KD-A725
03-22-2013, 10:14 PM
That's what I was saying!! Post back if you figure out what it is so I can get mine fixed!! The rattles drive me crazy!
03-22-2013, 10:25 PM
Real Name: Isaac
Real Name: Isaac
I'm having the same issue, its between roughly 2 and 3k rpms, and most noticeable under load, like accelerateintng or pulling hills or using the engine compression to slow down... I hope its not the back "y" pipe heat shield, cause if it is I'm not wanting to pull the motor, and I don't see a way to get to it with out pulling the motor. If I have to pull the motor in just gonna put a set of headers on...
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
03-22-2013, 11:01 PM
Real Name: Mason
Real Name: Mason
Does it sound like this...
https://www.youtube.com/watch?v=A9i8EYTsRrM
I get this sound at 2000 and 2500 rpm...
Happens at
:20
:29
:38
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
03-22-2013, 11:38 PM
Real Name: Isaac
Real Name: Isaac
Originally Posted by masphx
yeup, its more of a resonance vibration that a rattling sound. i dont think its my muffler, as its not coming from the back of the vehicle. it to me sounds like either the cat is lose(but i have no CEL) or in the engine bay
03-23-2013, 06:50 AM
got the same problem here, seemed like it got worse within the past month. i just cant pin point where exactly the rattle is coming from????????
03-23-2013, 08:41 AM
Yep, mine has been doing that for about the last 7000 miles. Not getting worse just worrisome at first. Nothing I can find loose under the truck and can't spot any exhaust leaks. I'm assuming it's the guts of the cat working loose. On one of my 95s it finally broke loose and rattled like crazy - you could hear it coming down the road. I don't remember it starting out this way but it probably did.
If anyone figures it out let us all know.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
