Old 09-11-2023, 05:11 PM #1
Whakeen Whakeen is offline
Whakeen is on a distinguished road
Fuel Pump Wiring Diagram
Hey Everyone,
I'm hoping someone can help with finding a wiring diagram for the Fuel Pump / Connector in an 02 SR5.
I actually have a Wiring Diagram (EWD471U) for an 02 but it does not match what is in my vehicle.
I've searched this forum and a general google search but have not found references specifically for 02 models which have different connectors than the 96-00 models.
I've attached a photo of the connector for the fuel pump from my 02 4Runner. Everything I've researched indicates it should be a blue/orange power wire and a white/black ground wire. Neither of these wires exist on my connector (there is a blue and white wire but they don't have the correct corresponding stripe colors plus this is an 11 PIN connector vs the 5 PIN ones I've seen for prior model years.
Any help is appreciated. Thanks!
Fuel Pump Wiring Diagram-02-fuel-pump-connector-jpg
Whakeen is offline   Reply With QuoteReply With Quote
Old 09-12-2023, 12:53 AM #2
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I don't think that is the fuel pump plug. Where exactly did you find it? On the rear seat strut, maybe? The five wire plug is under the access panel under the rear seat on the top of the fuel tank. I strongly doubt your rig is any different from all the others, unless maybe you have a 2003, not a third gen....
here is a pic of the access plate. The five wire plug is under there.
See the five wire socket on top of the tank?
My Backyard Frame Swap
Old 09-12-2023, 12:04 PM #3
TheDurk,
Thank you! I was in the right area but I didn't see the right connector. If you don't mind I edited your image to help someone in the future.
My apologies for wasting anyone's time. I was in a hurry and didn't read the manual thoroughly enough.
I won't have access to the 4Runner until tomorrow but this gets me back on track.
Fuel Pump Wiring Diagram-connector-png
Old 04-15-2024, 04:26 PM #4
HOGCAT HOGCAT is offline
HOGCAT is on a distinguished road
I hope that someone here can help me out. have a 1997 4runner v-6 that starts but dies as soon as you go from start to run with the key. It will run at high rpms around 3,000 but it sounds rough. Put a new fuel pump in it, but the other one has been tested and its good. HELP!!!!!
HOGCAT is offline   Reply With QuoteReply With Quote
Old 04-15-2024, 05:53 PM #5
TheDurk's Avatar
TheDurk's Avatar
First guess is Crank Position Sensor. Fuel pump will die if it doesn't get a good signal as soon as key is released.
Old 04-16-2024, 09:14 AM #6
Do you mean the cam sensor? I don't think it actually has a crankshaft sensor but it has a sensor on the passenger side by the camshaft pulley.
Old 04-16-2024, 09:28 AM #7
Also the idle control that lets it idle fast when cold and controls the idle speed when warm. You know what the proper name is. anyway it's location is just below the throttle plate and lets air bypass the throttle plate buzzes real fast (at least 15 times a second) I know it's controlled by a magnetic impulse that controls a drum that lets in air. The one I have on my V6 is white and has 3 wires going to it.
Old 04-19-2024, 11:55 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
NAME= AIC :-)
How to test and clean it.
Old 04-19-2024, 12:01 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
He means the Crankshaft Position Sensor.
Testing procedure here
Old 04-19-2024, 02:18 PM #10
TheDurk's Avatar
TheDurk's Avatar
I did indeed.
Old 04-24-2024, 01:03 PM #11
BuffaloBass BuffaloBass is offline
BuffaloBass is on a distinguished road
Those parts are relatively inexpensive. I replaced most of the sensors in my minor resto. BE CAREFUL OF THE WIRING CONNECTORS! I found my oil pressure wire broken, due to my handling or...? I donnow. Thankfully , all are also available, but do take care in unplugging anything.
BuffaloBass is offline   Reply With QuoteReply With Quote
connector , diagram , fuel , pump , wire
97 4Runner ECU/ECM wiring diagram/PIN diagram Dawgz 3rd gen T4Rs 5 02-20-2023 03:04 PM
Fuel Pump Relocation? or Fuel Pump Hatch? Cygnus 3rd gen T4Rs 3 01-24-2022 03:06 PM
Anyone got the diagram for connector G18 (electric wiring diagram) jicko 5th gen T4Rs 0 04-03-2015 10:01 PM
wiring diagram 99 fuel sending unit carkivey3 3rd gen T4Rs 14 12-09-2013 06:35 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
