Good deal for wheels and tires?
Cow_doc.308
I found these on CL and looks interesting. From what I've ready I think the rims will fit my 97 T4R and the tires should be about the max I can run without lift.
Toyota Parts
Any thoughts??
Doc
Thats the same diameter of a 265/75r16, so the tires should fit fine.
One thing I learned buying a set of those same "sport" wheels is that they have more backspacing than the stock wheels. A 265 tire should fit OK, but a 285 tire will definitely require wheel spacers. I have 1.25" wheel spacers, and I was unable to mount 315 tires to the truck using these wheels. The tires hit the UCA's with probably 1/4" to 1/2" to go before the wheel would even touch the spacer.
