12-19-2013, 11:47 AM
#16
Originally Posted by Doc2012
Where it says A/TM: Letter number number letter.
The second from the bottom on the right side.
Mine was A03A.
7.5" ring gear, 4.10 gear ratio, and 2 pinion open.
Yep, that is what it says on mine too A03A... Wanna sell your front diff? lol
12-19-2013, 11:49 AM
#17
will do
12-19-2013, 10:23 PM
#18
Location: Stationed in Camp LeJeune, home is Conover, NC
Lol. I would. except its 4.88s and an ARB air locker....
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
12-20-2013, 07:45 AM
#19
Real Name: Christy
Real Name: Christy
I have a 4:10 out of my 98, if you're interested. I'm in Iowa.
12-20-2013, 11:04 AM
#20
i will keep that in mind, the logistics is what i'd be worried about. I found one in Green Bay and was going to run up and get that tonight. Only an hour away. Thanks for the offer though. BTW when they say with ADD or W/O ADD what does that mean???? Anybody? Sorry not really a motor head guy.
12-20-2013, 11:12 AM
#21
locked both front and rear?
12-20-2013, 12:30 PM
#22
I was, until I destroyed my rear pinion, which led to the ARB failing.
Come tax time, or as soon as i get the money, which ever comes first, I will be locked front and rear again.
12-26-2013, 09:13 AM
#23
Real Name: Christy
Real Name: Christy
Automatic Disconnecting Differential. Basically, it's the alternative to having manual locking hubs (where you have to get out of the vehicle to lock/unlock by hand), because the A.D.D. system uses live hubs that are always locked.
12-26-2013, 02:19 PM
#24
Real Name: Eric
Real Name: Eric
Originally Posted by ar1five
whats the last 8 of your vin and the year?? I will get you the ratio..
any chance you can check mine too? mine is a 98, w0163605
12-26-2013, 02:40 PM
#25
You have a 4.30
02 sport 33"s --SOLD
98 Limited locked- 34.5" nittos, 3rd notch Bils on TRD Coils, 890s rear. 2" 4crawler BL(not installed) LED interior lighting, 1.5" wheel spacers, and torn seats!
12-26-2013, 03:02 PM
#26
Real Name: Eric
Real Name: Eric
You have a 4.30
thank you my man
01-08-2014, 11:55 AM
#27
Thanks to all you for your help, got the front diff put in last friday. Found a diff up in Green Bay for $125 and about 3 1/2 hours later we had it in. Had to jack up the transfercase a tad in order to pull it out but mad it a lot easier. Its back on the road looking to hit 300k. next up want to put in new timing belt and H2O pump. Anybody have any good Kits to recomend for this? Appreciate the help
Homer
01-08-2014, 12:18 PM
#28
I see you already have this swapped and figured out but you can also physically count the teeth on the ring gear now that you have it pulled out. You just need to crack the case on the front diff. Might also be a good learning experience.
85 Xtracab, 3Link Front, Marlin Dual Ultimate, Double Locked on 37s
01-08-2014, 04:08 PM
#29
Yeah, I'm glad you got this done correctly, because it's hard to believe that people still think you cat determine your ratio by the axle code... This has been debunked about a million times...
E-locked auto is usually 4.3 (or maybe it was auto with larger tires?), manual with larger tires usually had the 4.56, and everything else had 4.10. That may not be the actual rule, but from what people here have said, that seems to be the general rule.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
