Old 02-04-2014, 07:14 AM #16
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
Originally Posted by Boosterror View Post
Started on the light bar and wired up the headlights
Im a little ocd when it comes to wiring and take it to far sometimes.
Your wiring skills are (at least fit up) is outstanding. Makes me want to redo mine.
Everything looks great.seeing your fab skills, it looks like a hidden winch is in your future.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 02-04-2014, 12:05 PM #17
Boosterror Boosterror is offline
Boosterror is on a distinguished road
Thanks
98 limited 4wd.. E Locker, 2.5" lift 265/75/16 toyo mt
06 4runner sr5 2wd
04 rsx type s
Boosterror is offline   Reply With QuoteReply With Quote
Old 02-04-2014, 11:03 PM #18
Got everything finished up and the locker won't unlock.
06 4runner sr5 2wd
04 rsx type s
Old 02-05-2014, 12:16 AM #19
nor_cal51501 nor_cal51501 is offline
Real Name: Shane
nor_cal51501 is on a distinguished road
Real Name: Shane
DUDE!!! Nice job with the wiring. Where did you get the wire sheaths? And that sucks the locker won't lock up, any ideas yet what it is?
'01 Sport: E-locked, 285/70/17's, TURD S/C, 200k club
My Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
nor_cal51501 is offline   Reply With QuoteReply With Quote
Old 02-05-2014, 07:10 AM #20
Singtoe's Avatar
Singtoe's Avatar
At least fit up...
How did you wire your locker up - DPDT Switch, Relay pack or E-locker ECU. This will help in determining what wires to test.
In the mean time. Supply power and ground to the green and green w/red stripe to reverse the locker so you can drive it.
Old 02-05-2014, 07:30 AM #21
DPDT switch, I bought the harness from lowrange offroad. I hooked up fused +12 to the main hot and I grounded the white/black inside on the kick panel. If I click the switch nothing happens only the top part is lite with the ignition on.
06 4runner sr5 2wd
04 rsx type s
Old 02-05-2014, 08:00 AM #22
Singtoe's Avatar
Singtoe's Avatar
Check your switch for power and grounds. Your Locker lock unlock switch might be bad.
Old 02-05-2014, 01:09 PM #23
Cool thank you
06 4runner sr5 2wd
04 rsx type s
Old 02-05-2014, 03:29 PM #24
audiness's Avatar
audiness audiness is offline
audiness will become famous soon enough
audiness's Avatar
Nice work! what welder do you have?
audiness is offline   Reply With QuoteReply With Quote
Old 02-05-2014, 08:29 PM #25
Lincoln 3200 hd
06 4runner sr5 2wd
04 rsx type s
Old 02-05-2014, 08:39 PM #26
Got it, had the b/y swapped with the acc fused swapped. Works good.
06 4runner sr5 2wd
04 rsx type s
Old 02-06-2014, 03:40 PM #27
Thinking about moving the light bar back 2" farther in the grill just not sure if it will effect the light output
06 4runner sr5 2wd
04 rsx type s
Old 02-06-2014, 04:00 PM #28
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Boosterror braiDED wire
[QUOTE=Boosterror;1613486]
Dude. Looks sick so far..
Question: where did you get that braided wire for your accessories??
Is that the wire itself or sheathing you put on after the fact?
Thanks.
Any links to the places you purchased would be appreciated
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 02-06-2014, 10:49 PM #29
I get it here in town its a nylon sheathing that slides over the wire. I found this place nylon-expandable-braided-sleeving
Looks to be the same stuff, I really like working with it and the nice heat shrink with the glue in it makes the job look better.
06 4runner sr5 2wd
04 rsx type s
Old 02-07-2014, 10:12 PM #30
And the hits keep coming right front axle is slinging grease and I gone pinion noise.
06 4runner sr5 2wd
04 rsx type s
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
