Old 04-20-2014, 09:24 PM #1
tacokiller's Avatar
tacokiller tacokiller is offline
tacokiller is on a distinguished road
tacokiller's Avatar
Broken cv inside front diff
How do you get the broken part of the cv shaft out of the front differential? It snapped fully insides front diff and I have know clue how to get it out. Thanks for the help.
tacokiller is offline   Reply With QuoteReply With Quote
Old 04-20-2014, 09:26 PM #2
hearno's Avatar
hearno hearno is offline
hearno is on a distinguished road
hearno's Avatar
you might want to post pics to help with a better idea of what the problem is.
2014 Trail
A mild build She gone... sad face.
2001 Limited 4x4
hearno is offline   Reply With QuoteReply With Quote
Old 04-20-2014, 09:32 PM #3
tacokiller's Avatar
tacokiller's Avatar
here the photo!
Broken cv inside front diff-image-jpg
Old 04-20-2014, 09:35 PM #4
tacokiller's Avatar
tacokiller's Avatar
here a side by side comparison.
Broken cv inside front diff-image-2-jpg
Old 04-20-2014, 10:21 PM #5
AZ_Trails's Avatar
AZ_Trails AZ_Trails is offline
AZ_Trails is on a distinguished road
AZ_Trails's Avatar
I've read about others having the same issue. If I remember correctly, they drilled and tapped the end of the axle, screwed in a bolt, and pulled it out. Sounds like a major pain. What brand axle was this?
2018 Toyota 4Runner TRD Off Road Premium
Mostly Stock...TRD Pro Grill & Valences, 265/70R17 KO2s on TRD Pro Wheels, Toyota Rock Rails
2000 Toyota 4Runner SR5 4WD 5-Speed
Sonoran Steel 1.2 w/ OME 861s, 4.56 Gears w/ ARB Front & E-Locker Rear, AOR Front, CBI Rear, 285/75R16 KO2s, Custom Full Length Rack, BudBuilt Skids, Lil' Skip's Gas Tank Skid, Savage Sliders
AZ_Trails is offline   Reply With QuoteReply With Quote
Old 04-20-2014, 10:23 PM #6
tacokiller's Avatar
tacokiller's Avatar
Hmmm that is a pain. But they are the stock toyota axels actually!
Old 04-20-2014, 10:26 PM #7
hearno's Avatar
hearno's Avatar
that sounds like a decent option
2014 Trail
2001 Limited 4x4
Old 04-20-2014, 10:37 PM #8
TBuzz's Avatar
TBuzz TBuzz is offline
TBuzz is on a distinguished road
TBuzz's Avatar
When the CV breaks at the inner axle shaft extraction or teardown are the two options. The broken shaft in inaccessible by simple measures.
-Jack and support front end safely
-Remove tire, damaged CV and shock assembly (Plenty of write-ups on CV removal)
-Mark and indent center of broken shaft
-Wedge paper into the bottom of the housing to catch metal shavings
-Make sure your drill fits into the tight space at a straight angle. If the drill does not fit removal of the LCA is required. The DeWalt I used was big and had to be operated upside-down to get a straight line on the shaft
-Use a 5/16 cobalt/tungsten carbide tip bit for drilling. Drill a pilot indention with 4WD disengaged to spin the shaft and center the hole more easily
-Engage 4WD and front locker and drill approximately ½ inch deep
-Start the 3/8 tap by hand and continue with a wrench. Back the tap out every so often to clean the threads and clear metal particles, wasted gear oil will assist the tap
-Thread the 3/8 bolt and remove the shaft with a slide hammer. The Harbor Freight model I used was 3/8 and threaded directly into the shaft. Otherwise use a 3/8 bolt and slide hammer jaws. (in the tools pic note the shaft piece at the end of the slide hammer)
-Thoroughly clean the housing to remove any shavings/debris
-Change the diff fluid and check the drain plug for metal after a few miles if need
00' Highlander, no longer stock
TBuzz is offline   Reply With QuoteReply With Quote
Old 04-20-2014, 11:30 PM #9
snivilous's Avatar
snivilous snivilous is offline
snivilous will become famous soon enough snivilous will become famous soon enough
snivilous's Avatar
I would just weld something too it, or is that looked down upon for some reason?
snivilous is offline   Reply With QuoteReply With Quote
Old 04-22-2014, 11:51 PM #10
tacokiller's Avatar
tacokiller's Avatar
I just want to give a big shout out to TBuzz for all the help today helping me drill and tap the little part of my cv axel out of my front differential. Long day I really hope to never snap a cv inside the front differential ever again!!!
Broken cv inside front diff-image-3-jpg  Broken cv inside front diff-image-jpg  Broken cv inside front diff-image-2-jpg
Old 04-22-2014, 11:57 PM #11
hearno's Avatar
hearno's Avatar
rep @TBuzz for helpin out a bro
2014 Trail
2001 Limited 4x4
Old 04-23-2014, 12:00 AM #12
TOY2G TOY2G is offline
Real Name: Nathan
TOY2G will become famous soon enough
Real Name: Nathan
Pull the other side CV and knock out the broken part from the opposite side with a long bar or screwdriver.
TOY2G is offline   Reply With QuoteReply With Quote
Old 04-23-2014, 03:17 AM #13
snow junky's Avatar
snow junky snow junky is offline
snow junky is on a distinguished road
snow junky's Avatar
i would have just cracked open the clam shell.... wouldnt want any of the shavings going through the gears.
97 4runner 3rzfe 5speed
D44 sky mfg sas
Dual transfer cases
toyo 37s 5.29 locked F&R
York OBA compressor
snow junky is offline   Reply With QuoteReply With Quote
Old 04-23-2014, 03:37 AM #14
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
That would work, but I don't know how you'd get a welder on it. The shaft snapped inside the diff itself.
Way to go, TBuzz.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 04-23-2014, 03:42 AM #15
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Not by me. I've used that method several times, and also suggested using it on this forum.
Hit the end of the broken axle shaft with some brake clean, tack weld a bolt to it, attach a slide hammer, and pop it out in under five minutes.
The quick tack weld doesn't produce enough heat to damage the oil seal, and it's a lot easier than drilling and tapping.
Of course it does require a welder, which not everyone has.
02SE is offline   Reply With QuoteReply With Quote
Ice, Donuts, 4lo, diff lock, POP!!!! is it broken? helo please Dubs Chops General Discussions 18 03-03-2014 12:04 AM
Broken diff cover bolt-need advice mcaz5 3rd gen T4Rs 5 10-23-2013 08:48 AM
pics-4th gen V8 Running without front drive shaft? rwd? broken diff. bracket bctrunner 4th Gen T4Rs 23 06-26-2013 04:44 PM
Broken Rear Diff Breather blonde1boarder 3rd gen T4Rs 2 04-15-2013 03:46 PM
So my backdoor lock cylinder broken inside the door T4RArmorLT 3rd gen T4Rs 2 09-05-2011 08:33 PM
