Old 05-13-2014, 12:53 PM #1
ShooterMcGavin's Avatar
ShooterMcGavin ShooterMcGavin is offline
ShooterMcGavin is on a distinguished road
Popped out of first gear (5-speed)
I was driving my '97 5-speed yesterday and it popped out of first gear twice during one day. I have experienced it pop out of first before, on separate occasions. Yesterday, it came out of gear once at very light throttle, and then under heavy throttle as I was starting on a hill (loud POP). I have only owned the truck for 1,000 miles and it has a total of 263,000 miles on it. My questions...
Would a tranny fluid change help keep this situation to minimum, or even make it worse? Is there any special maintenance that can keep this from becoming a constant problem? Or, is it inevitable that once it starts popping out of gear, it only gets worse from there (like a clutch starting to slip)?
Thanks.
ShooterMcGavin is offline   Reply With QuoteReply With Quote
Old 05-13-2014, 03:02 PM #2
So Many Roads's Avatar
So Many Roads So Many Roads is offline
So Many Roads is on a distinguished road
I had similar problems. It would pop out of first gear when not fully engaged.
I replaced the manual transmission fluid (used amsoil, others swear by redline) and replaced the shift lever bushing with one from marlin crawler. Much improved, but it still happens occasionally when I am lazy and don't get the shift lever all the way into first.
'99 SR5, 5 spd, Bilstein 4600, elocker mod, TBU
So Many Roads is offline   Reply With QuoteReply With Quote
Old 05-13-2014, 07:14 PM #3
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: I'm Gumby, damn it
fourwd1 is a glorious beacon of light fourwd1 is a glorious beacon of light fourwd1 is a glorious beacon of light fourwd1 is a glorious beacon of light fourwd1 is a glorious beacon of light
Moderator
fourwd1's Avatar
Try replacing the shifter seat.
It's a rubber bushing that hardens a cracks over time.
Look here
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 05-14-2014, 12:19 AM #4
Thanks.
SoMany, are you talking about a bushing like the one fourwd linked me to? For that price, I'll definitely give it a try. I need to order the oil to replace first.
Old 01-07-2019, 08:48 AM #5
Cbrown Cbrown is offline
Cbrown is on a distinguished road
TRied this Didnt work Any other solutions?
I have replaced the shifter seat but it did not help my situation. Now my First gear is always popping out and hard to get moving. Has anyone had similar issues and solutions?
Its a 2000 SR5
Cbrown is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 10:03 AM #6
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Its a 2000 SR5
Yeah I have had that happen. With a "beat" 5 speed, you have to make a more concerted effort to make sure you fully push all the way into 1st. If you do a lazy shift you may not fully lock it in and it can pop out. I had a 300K 5 speed that would do that, was also loosing its syncro, would get grinding on normal shifting occasionally going from 1st to 2nd. So my gears were getting beat. I ended up finding a cheap low mileage 5 speed for $250, had it torn down and rebuilt regardless, in hindsight I should have just installed as is, but I wasn't sure about the "low mileage". You can put in new gear lube, may help a bit. But keep your eyes out for a good replacement low mileage transmission, or expect a rebuild, aprox $1K not not including remove and install, but good if you can do your own install. In the mean time, use extra effort and make sure you're fully engaged all the way into 1st.
dogtail is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 02:12 PM #7
3bears 3bears is offline
Real Name: 3 Bears
3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold
Real Name: 3 Bears
could also be the shift forks, internal, which I have seem when people like to ride and hold the shifter, then it starts popping out of gear and they hold it more into gear, wearing the shift forks faster.
I would try the easier cheaper fixes listed above first
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 01-07-2019, 05:52 PM #8
suncoug suncoug is offline
suncoug is on a distinguished road
Mine does that occasionally. However, it only does it if I don't fully engage the first gear. Also, it only does it when I start moving but never while moving. It is annoying but I don't see it as a huge problem.
suncoug is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 08:06 PM #9
davidch davidch is offline
davidch will become famous soon enough
The items I call fulcrum pins in the transmission tower may be loose and this might cause a problem in which a given gear is not fully engaged. I wrote this up once before, with a picture, so it'll be clear what I'm writing about.
https://www.toyota-4runner.org/1915180-post19.html
At any rate, it's easy to check.
davidch is offline   Reply With QuoteReply With Quote
My R150F (5-speed manual) transmission is hungry for gear oil? brocktice Classic T4Rs 1 11-28-2013 08:03 PM
Popped my 3rd gen cherry brosama 3rd gen T4Rs 10 09-09-2013 02:15 PM
5 Speed Manual Pops out of 1st Gear.. Hmmm?? sephryan Classic T4Rs 6 04-04-2013 03:36 AM
antenna popped out need help 2012blzdwht 5th gen T4Rs 7 08-24-2012 09:32 PM
Reverse gear/speed sensor input jsukey Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-01-2012 11:38 AM
