06-10-2014, 09:30 PM
Cabin filter
Hey there guys - just wondering if the '97 4runner has a cabin filter and if so do you know where its located? I checked behind the glove compartment but no dice. Thanks.
06-10-2014, 09:33 PM
No 3rd gen 4Runners have a cabin filter from the factory.
06-10-2014, 09:34 PM
Not that I know of, nope.
06-10-2014, 10:16 PM
I just cleaned mine and wow, made a huge difference......my AC about freezes me out now. I think everyone should do this every so often.
- 2005 Sport, V8, AFE CAI, URD MAF Calibrator, Doug Thorley ST Headers, Gibson SS Exhaust, ICON Stage 1, LR UCA's, FN BFD's, Michelin LTX Defender M/S 265-60-18's, ADDCO Front/Rear Sway-bars...lots of smiles every time I get behind the wheel....
06-11-2014, 11:01 AM
I should do this with mine.
New Rig:
2008 Tundra 4x4 Crewmax Limited
Old Rig:
1997 SR5 3.4L Auto 4x4, Over 300k miles...
06-11-2014, 12:02 PM
Thanks for posting that link, mine has been making a noise and definitely needs a cleaning!
2001 Toyota 4Runner SR5 Sport
Imperial Jade Mica
231mm Tundra Brakes
5100 Bilstein / TRD / OME 890 3" Lift
285/75/16 BFG KO2s
06-11-2014, 12:04 PM
Originally Posted by jonnieguns
Thanks for the link - I'm sure mine is ready for a cleaning as well.
2000 Highlander - 3" OME 883F 890R - ARB F&R Lockers - AOR Bumper - Savage Armor - WARN M8000 - RIGID LED Floods - TRD Wheels - TBU - HID - BFG KM2
06-11-2014, 06:42 PM
I just did this due to the fact my fan swallowed two acorn husks and sounded like an Airbus on take-off roll. I disagree with Bob's write-up. There is no reason to remove the glove box, it really doesn't help. You DO need to pull the right kick panel.
1. Remove two forward screws from the plastic trim along the door opening, and lift the front edge away from the bottom of the kick panel.
2. Pull the kick panel BACKWARDS about two inches, which is all it easily goes. Then raise the bottom sideways towards the center console until it is loose.
3. Then remove the three screws and lower the fan. Ideal implement for removal of the three screws is a 1/4" ratchet, short extension, and a T25 bit. It looks like an 8mm hex would also work, but the Torx #25 works great.
Surprisingly, although the fan had never been cleaned in the 15 years I have owned the truck, it was almost pristine, just a light coating of dust.
My Backyard Frame Swap
06-12-2014, 04:28 AM
I cleaned my fan last night after seeing this thread. Tested the AC today, it was nice not having a funky dirt smell filling the cabin after I turned off the AC!
Jason
1985 fj60
2006 4runner v8 4x4 sport
http://www.jasonredwoodart.com
06-13-2014, 02:20 AM
Thanks for the link jonnieguns that really helped out. I scoured the internet trying to figure out if the '97 had a cabin filter and gave up and just opened the glove box. Little did I know the filter was right there and could be cleaned out like you said. Gonna do that this weekend, thanks!
