Old 06-16-2014, 05:44 PM #16
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
Had this happen on one of my DSM's. I had let it all dry out and still no start. Found the CAS had water inside. Had to oven bake it dry till it would work again. Glad you got her going.
JayRolla is offline   Reply With QuoteReply With Quote
Old 06-16-2014, 10:13 PM #17
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
I would pull the plugs out and clean them.
There is no way OP could have hydro locked it or messed up his engine by washing it with water right guys ?
Is it to risky to rinse it with water ?
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 06-16-2014, 10:32 PM #18
shootmymime's Avatar
shootmymime shootmymime is offline
shootmymime will become famous soon enough
No need to pull the plugs.
No way to hydro lock a motor.
You can still have this miss fire symptom when you add water into the equation.
Check the spark plug wells again. Spray them with wd 40 and inside the boot.
I've had this happen on my 96 years ago.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
shootmymime is offline   Reply With QuoteReply With Quote
Old 06-16-2014, 11:11 PM #19
RussToy's Avatar
RussToy RussToy is offline
Real Name: Russel
RussToy is an unknown quantity at this point
RussToy's Avatar
Real Name: Russel
X2 what @shootmymime said. Most people don't know this...but WD-40 was devolved for NASA to remove water from electrical components. Hence the WD...water displacement. And on the 40th attempt...they had a formula that worked...and poof, there you have it WD-40. It wasn't until later, people began using it as a lube.
Anyway, just like shootmymime said...spray the spark plug well and boot with the WD-40 and it will remove all the moisture. You should be in business...unless its a coil!
RussToy is offline   Reply With QuoteReply With Quote
Old 06-16-2014, 11:23 PM #20
Hog1983 Hog1983 is offline
Hog1983 is on a distinguished road
I clean my engine compartment at least every 6 months. I never cover anything other than my deckplate. I also pull all the electrical connections and put some di electric grease in them at the same time.
Hog1983 is offline   Reply With QuoteReply With Quote
Old 06-16-2014, 11:55 PM #21
Asaspades93's Avatar
Asaspades93 Asaspades93 is offline
Real Name: Asa
Asaspades93 is on a distinguished road
Real Name: Asa
Originally Posted by Thorgan112 View Post
So what did you do? Just open the hood and let it dry out? I have a feeling it's either the coils or the sparks
Sorry I just got home from work. I was having a problem with the coil before, but temporary fixed it before completely messing it up when washing. At first I pulled the coils and boots for 5 hours and that didn't solve anything so I just ordered a denso coil off of amazon for 60 and its been running perfect ever since
It does help to know which cylinder is misfiring though so you can also order a scanner on amazon
96 SR5, Ghetto ISR mod, SCS Stealth 6s, 35x12.5 Toyo MTs, Bilstein 5100s/Eibach coils, B&M Transmission cooler, 1.5 Inch Fat Pat body lift, OME 851s, TJM XGS Gold series LC shocks, Satoshi grill, Rear diff breather, 167 series snorkel, Toytec rear brake line, All Pro apex Front bumper with custom hoops, Custom rear bumper with Ghetto swing out, First Gen roll bar,LED parking lights/turn signals, Hybrid model
Asaspades93 is offline   Reply With QuoteReply With Quote
cleaning , engine , idle , rough
Tell me why I shouldn't do it! Shoke 3rd gen T4Rs 38 03-29-2017 03:31 AM
You can but you shouldn't NoDak Off Topic 3 04-01-2014 07:19 AM
Gas where it shouldn't be? Steven94 Classic T4Rs 7 08-26-2013 08:50 PM
Check engine light after fuel injectors cleaned at Midas FiredUp 3rd gen T4Rs 6 02-14-2012 12:16 PM
should i or shouldn't i??? konawoodard 4th Gen T4Rs 9 01-05-2007 12:30 AM
