Old 02-14-2015, 07:37 PM #1
haw_haw_haw haw_haw_haw is offline
haw_haw_haw is on a distinguished road
Alternator mod gone wrong
So about a year ago, I installed a CS-144 alternator in my 2001. It's worked great up until a couple days ago.
My door speakers had been cutting out in the middle of use, so I took the car to my audio shop, thinking there was a problem with my amp. They ended up finding out that my alternator was charging at around 18 volts. I haven't been able to find much on this issue, but I read that there's an external voltage regulator somewhere. Also, the audio shop said something about a bad diode in the alternator.
So my question is: does anyone have any experience with this? Is the voltage regulator something I can just swap out, or will I need a new alternator? And if the problem is a diode in the alternator, can that be fixed?
Thanks in advance!
haw_haw_haw is offline   Reply With QuoteReply With Quote
Old 02-14-2015, 09:53 PM #2
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
Did you get a lifetime warranty? If so take it back. How did you splice the GM connector to the toy harness?
Old 02-14-2015, 10:44 PM #3
MojaveMadMan's Avatar
MojaveMadMan MojaveMadMan is offline
Real Name: Chris
MojaveMadMan is on a distinguished road
Real Name: Chris
You can find them easy, just google it. I found my connector that way.
MojaveMadMan is offline   Reply With QuoteReply With Quote
Old 02-15-2015, 12:55 AM #4
I'm not sure if I have a warranty or not, but that's a good idea. I'll go back to where I bought it and see if they have my info.
Old 02-15-2015, 09:10 AM #5
jeremyc74 jeremyc74 is offline
Banned
jeremyc74 is on a distinguished road
Banned
Thanks in advance!
I haven't done one in a while, but you should be able to just replace the regulator and the diode pack. You have to take the alternator apart, but it's not a big deal. The parts are generally a lot cheaper than replacing the whole thing. You can also test the diode array using a basic multi-meter once you get it apart. There's also a third part in there called a diode trio (or something like that) that's cheap so I'd replace that while I had it apart.
jeremyc74 is offline   Reply With QuoteReply With Quote
Old 02-15-2015, 11:32 AM #6
Watch a bunch of videos on taking it apart. I'd remove it and have it tested at a parts store. If it's bad and under warranty replace it.
Do you have a multi meter? If so with engine running read voltage across the battery posts. See what you got. Above 14.7v is bad.
Old 02-15-2015, 11:34 AM #7
When you get back to up also answer how you made the alt connections between the GM Alt and the Toy harness.
Old 02-15-2015, 03:55 PM #8
The audio shop I took my car to was reading around 18v with the engine running. That was measured across the battery terminals. It already blew out my low beams, and it's been throwing my amp into protect mode.
Old 02-15-2015, 03:57 PM #9
It was just plug and play wiring wise. Getting the alternator in was a pain, but like someone stated above, there's tons of adapters. I found one for around $10, but I don't remember the website I used.
EDIT: I'm pretty sure I got the harness from this website. http://store.alternatorparts.com/wir...tyle-plug.aspx
I don't remember it being that expensive, but that looks like the correct harness.
Old 02-15-2015, 04:00 PM #10
That's some good advice, thank you! I'll research taking them apart and see about finding the regulator and diodes for a CS-144 online
Old 02-15-2015, 08:46 PM #11
I found my original receipt for the alternator. I bought it at Advanced Auto Parts, so I'm going to see if I can just exchange it rather than messing with taking everything apart. Thanks to everyone for their advice! I'll give an update when I've got everything back to normal.
Old 02-16-2015, 12:52 PM #12
TXRick TXRick is offline
Real Name: Mr. Allen
TXRick is on a distinguished road
yeah, good idea. I've messed with cs144's for years because I used to daily drive a 96 eldorado. I've replaced several and they arent as easy to mess around inside one as other alts. For instance, no external volt regulator you just unscrew and replace, but its still a well made piece of equip. The Eldawg has been sitting for a few years with a new alt in it...I may take it out and put it in the runner
TXRick is offline   Reply With QuoteReply With Quote
Old 02-18-2015, 11:20 PM #13
Exchanging the alternator at advanced worked. I just had a shop switch them out because I didn't feel like working on my car in the cold. Now I'm doing a big 3 upgrade and switching to a deep cycle battery. Hopefully that'll be the end of my electrical problems for good!
2001 4runner , 3rd gen , alternator , cs144 , electrical problems
What went wrong? zooroadbaja 3rd gen T4Rs 12 08-08-2013 08:02 PM
Is it so wrong? that$pit 3rd gen T4Rs 11 05-29-2012 11:24 AM
What am I doing wrong??? two4runners 5th gen T4Rs 15 12-29-2009 09:16 AM
is something wrong with me? itsallmine 4th Gen T4Rs 17 05-20-2005 07:24 PM
