Old 03-19-2015, 09:07 PM #16
Shadance Shadance is offline
Shadance is on a distinguished road
I checked the relay 4 without the switch grounding n have no power showing there. I have used a test light on that at this point. I will check the fuse contact points with my meter.. I verified continuity for the fuse s I know it's good..
Shadance is offline   Reply With QuoteReply With Quote
Old 03-19-2015, 09:24 PM #17
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
I believe you that the fuse is good, but is there POWER at the fuse?
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 03-19-2015, 09:43 PM #18
So the right is giving me 14v n nothing on the other side..
Old 03-19-2015, 09:44 PM #19
That means the fuse is NO GOOD
Old 03-19-2015, 09:45 PM #20
If you replace it and it blows, we'll need to look for a short! Yay!
Old 03-19-2015, 09:53 PM #21
This is with the fuse pulled. Fuse has been rechecked. Not sure how u would check it with the fuse in place...
Old 03-19-2015, 09:59 PM #22
Poke the opening at the top, but if the fuse is still good, you are good. So if there is NOW power at both sides of the fuse, and for sure no power to DRL Relay #4, the open is most likely at the connector in the driver's side kick panel. IG3, as I suggested in an earlier post.
Old 03-19-2015, 09:59 PM #23
Got the boyfriend with his meter n he was able to check both sides n there is power to both sides with the fuse in place..
Old 03-19-2015, 10:07 PM #24
OK, so the next step is to look for that connector in the kick panel.
Old 03-19-2015, 10:27 PM #25
It's good on both sides... I pulled the connector apart n checked it n then put it back in n checked it n test light verifies power. That was a major pain in the but to get out to check..
Old 03-19-2015, 10:33 PM #26
So just rechecked the 4 relay n it has power. Key thing to do when checking make sure vehicle is running....... it doesn't have power otherwise... N reverified that there is no power with just the key in the on position.. so not sure where to go from here if these r all working...
Old 03-19-2015, 10:33 PM #27
Wow, so that leaves the wiring from the kick panel to the Relay#4. You should run a temporary jumper to T4 on the relay and see if that allows your headlights to work. If it does, it might be simpler to run a new permanent wire than to open the harness up looking for an open. Recheck the connector for that relay, maybe the wire is bad right there!
And I know you said it doesn't have power, but triple check it, and make sure it is the right one. Is it a yellow wire?
Old 03-19-2015, 11:07 PM #28
See my post above ur last post.. Kind of frustrated with the whole thing right now since alot of what I've checked wasn't working cuz it wasn't running..
Old 03-19-2015, 11:28 PM #29
Well actually, that is a good thing, so if the relay has power, and you grounded T8 at the switch connector to make it work. It means your problem is most likely in the main DRL relay. But please confirm that T16 at the switch has a good ground. Then there are a few more things to check.
I understand your frustration. But we'll get it!
Old 03-20-2015, 01:02 AM #30
Not totally sure how to check 16. If taking the test light n grounding it n pushing it into the connection I get nothing.. if that's not what u mean let me know how to test it..
Solara headlight switch (DRL off?) velomatt 3rd gen T4Rs 2 08-26-2017 10:32 PM
FS: 3rd Gen Headlight Switch W/O FOGS THatfield For Sale: T4R Items 0 08-24-2013 11:35 PM
Headlight switch Philthyphil 4th Gen T4Rs 2 12-21-2010 12:49 PM
headlight switch w/ fog light switch oxfordethan 3rd gen T4Rs 1 10-15-2007 09:34 AM
HID not shutting off using the headlight switch blindside 4th Gen T4Rs 7 02-21-2007 03:53 PM
