04-30-2015, 10:13 PM
Real Name: Vince
Real Name: Vince
"Rebuilding" a Toytec Ultimate coilover
So I am running a Toytec Ultimate. This weekend I will be replacing one of the shocks due to a bad valve (causing horrible vibration at highway speeds and cupping of the front tire). I really like the Ultimate, but it bugs me that the fronts are not rebuildable.
So here is my question... Has anybody replaced the Bilstein shock with a similar threaded body shock? Sway-A-Way has a 2" threaded body that has nearly identical specs (compressed/extended length, stroke, etc...), and it is completely rebuildable. Is there any reason that I couldn't do that? Basically I would be keeping the Eibach springs and the aluminum top mount. Looking at SAW's website, this would be significantly less $$$ than buying their complete coilover kit.
'99 Millenium Silver SR5. Auto, Shrockworks front bumper, Engo winch, Tundra 231mm, Toytec Ultimate lift, Light Racing UCAs, Tundra wheels, 285/70/17" Duratracs, B&M trans cooler, Whitson Metalworks short roof rack.
04-30-2015, 10:27 PM
Real Name: Tyler
Real Name: Tyler
Not that I know of. Interesting idea though. Biggest issue I see is fitting the SAW top cap into the toytec mount. Hard to tell the mounting width, you may not be able to get a misalignment spacer small enough.
2000 4Runner:Kings, 37s, lockers 2018 TRD OR:stock and staying that way
05-01-2015, 05:43 AM
off the subject here. I'm thinking of getting the ultimate kit. do you have some pix of it on your rig you can share possibly? and how does it ride as daily?
1993 Honda Accord EX | 5 speed
2000 T4R Limited | TRD SC w/ URD 7th injector and factory rear diff lock
1994 T4R SR5 | 5 Speed 4WD SOLD
2007 Subaru STi | Stage 2
05-01-2015, 03:46 PM
We do have replacement shocks for the Ultimate coilovers available.
Unfortunately they are $199 per shock and that has been the cheapest we have been able to get them for. If you need them, give us a call and we can get you some
Dylan
05-01-2015, 04:17 PM
Real Name: Instagram: briansd_97r
How did they break, how long did they last?
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
05-01-2015, 05:25 PM
Real Name: Robert
Real Name: Robert
Honestly it will probably be easier, cheaper and better to just get new coilovers. I've never ran the Toytec coilovers, but never found the appeal besides the price tag. $200 per shock isn't horrible, but considering a coilover rebuild is about $100 for both shocks if done by yourself it definitely reduces the allure of the 5100 coilover.
Good luck and let us know how it worked out for you.
My 4runner Build Thread 2000 Limited 4runner SOLD
My Tundra Build Thread 2006 Double Cab Tundra SOLD
My Humpty Dumpty 4runner Build Thread 1999 Highlander 4runner
05-01-2015, 05:47 PM
Real Name: Vince
Real Name: Vince
@ ToyTec Lifts
I already have my replacement, I ordered it last week. As for the $200 price tag, It really is a pretty good price for that shock. I think the cheapest that I have seen from other sources was about $240. You guys definitely offer very good customer service.
I really doubt that I will ever try to "frankenstein" a coilover. But being a guy that likes to tear stuff apart and try to put it back together, I was just curious to see if anyone had tried this.
@ BrianSD_42
The original lasted me right at 2 years. It probably would have lasted even longer, but I must have had it cranked up a little to high. I'm going to lower both fronts about 1/2".
12-09-2015, 12:54 AM
Real Name: Ian
Real Name: Ian
@ ToyTec Lifts
@ BrianSD_42
My 650lb toytec coilovers are starting to cause vibration at around 60mph after 2 years of use. I am not positive that they are the culprit, but I just had an alignment and had my tires rotated/balanced. I may be looking to switch to some ICONs here soon.
1996 Desert Dune SR5 - Toytec Lift - Rear ARB Locker - 4.88 Gears -315/70/17 Mickey Thompsons - FN Wheels 17" 5 stars - Shrockworks Front Bumper w/ Warn 9.5xps - Stubbs HD SKO Sliders - 2nd Gen Supercharger w/ Stock Pulley
build thread
12-09-2015, 06:17 PM
Real Name: Vince
Real Name: Vince
Check to make sure that your tire tread isn't cupped or feathered. A bad strut will definitely cause that, and that is where the vibrations really start to get bad. To get rid of my vibration, I had to replace the shock and the bad tire.
