Old 08-16-2011, 08:37 AM #1
Maritimer's Avatar
Maritimer Maritimer is offline
Maritimer is on a distinguished road
Maritimer's Avatar
Lateral Rod ?'s
I had my lateral rod behind the rear axle off for some grinding and painting in the area, and now the bolts are giving me grief.
I was off-roading on Saturday and it got a bit loose and made the rear end sloppy and let it squeak and bump. I tightened it and now it seems to be sticking and letting go with a loud ping.
Basically I guess I need to find the right amount to tighten it, but I was wondering if it is handed? I got it all swung around when I was cleaning it and I'm not sure how to tell if there is a right and left side. I figure the torque on the bolts means squat if it's on "backwards".
2001 SR5 4X4, V6, 3.4L
Maritimer is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 08:56 AM #2
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
Tighten it some more. The is no orientation for the pan hard bar except for the 2wd models that have a brake proportion valve attached to it.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 09:10 AM #3
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Yeah, I have had the same exact thing. Mine was loose and was knocking. I still have a knock even after tightening it, but I am not sure it is the panhard. I am replacing my panhard soon though as mine is bent, so we'll see if that helps.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 01:01 PM #4
Maritimer's Avatar
Maritimer's Avatar
Cool. I know exactly where the sound is coming from because I got my wife to drive forward SLOWLY while I kept my hand on the joint.
It felt like it was the front sway bar link because that's where the foot feels anything happening through the frame, but it still did it after I replaced that yesterday (it was toast anyway).
Old 08-16-2011, 05:56 PM #5
Maritimer's Avatar
Maritimer's Avatar
I got rid of the ping.
I took the bar off and checked the bushings, and one side had more rubber, so I switched it around. I figure that 10+ years have made the bushings happy where they were and that I had switched them around. Then I tightened the bejeezuz out of them. Problem solved.
Wouldn't mind putting new bushings on in the future for the hell of it.
Old 05-04-2017, 10:49 PM #6
flipty flipty is offline
Real Name: Dave
flipty is on a distinguished road
Real Name: Dave
Sorry to zombie-revive this thread, but are the Lateral Bar's bushings the same as the lower control arms' bushings? Because I've got two extra lower ones and I'd love to get new bushings into the lateral.
flipty is offline   Reply With QuoteReply With Quote
Old 04-19-2018, 11:34 AM #7
andres4runner andres4runner is offline
Real Name: andre
andres4runner is an unknown quantity at this point
Real Name: andre
I need to do my lateral rod,can I get just bushings,the rod id big money
andres4runner is offline   Reply With QuoteReply With Quote
Old 04-19-2018, 02:19 PM #8
pauldub pauldub is offline
pauldub will become famous soon enough
It's called a track bar or panhard rod in the automotive world.
pauldub is offline   Reply With QuoteReply With Quote
Old 04-21-2018, 01:39 PM #9
Real Name: andre
Real Name: andre
they are different ,can any one measure them and get replacements I'm striking out..they are smaller.
Lateral Control Rod RHU Classic T4Rs 0 07-10-2008 01:53 PM
