Old 01-17-2017, 07:50 PM #1
blockhead blockhead is offline
blockhead is on a distinguished road
Valve Cover Leak
Based on what I've seen it looks like my valve cover is leaking a bit (175k, so no big surprise, I guess). I did notice what looks to be leaking at the PCV(?) valve also. Does this suggest that there's blow-by from a cylinder or two causing pressure and leaking? Or maybe a PCV valve problem is part of the cause...
One picture is the PCV, the other is the spark plugs with 55k on them (probably should have done sooner).
Valve Cover Leak-img_5484-jpg  Valve Cover Leak-img_5481-jpg
Stepsons 2000 4Runner Limited. E-Locker..Tundra 199mm Brakes. Blue Wire Mod. 3" OME 891 rear & Tundra TRD front. Duratrack MT 265/75 R16. TRD Trans Cooler. DRL Disable. Legal Limit Tint.
2004 Tacoma 4WD (Sold). / 2004 LR Discovery. 3" OME. (Sold) / 1982 CJ7. 4.0 MPI. (Sold) / 1989 YJ (Sold) / 1985 4WD Toyota Pick-Up (Long Gone!) 🤫 back to the dark side Land Rover LR4 for me..
blockhead is offline   Reply With QuoteReply With Quote
Old 01-17-2017, 07:57 PM #2
That looks pretty normal. You'll want to get a new PCV valve, grommet and hose.
I wouldn't think that there is any excessive blow by, just normal PCV operation and old/cracked rubber parts.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-17-2017, 08:01 PM #3
Cool, thanks, I'll do that. Found this too, which is probably one of the hoses you mentioned.
Valve Cover Leak-img_5479-jpg
Old 01-17-2017, 09:46 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you decide to replace your valve cover gaskets, @infamousRNR and I have a video you can use as a guide to get the job done.
Old 01-17-2017, 10:08 PM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I have to ask how dirty is your throttle body/IAC? Change that PCV ASAP!
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 01-17-2017, 10:55 PM #6
AZBub's Avatar
AZBub AZBub is offline
Real Name: Chris
AZBub will become famous soon enough AZBub will become famous soon enough
AZBub's Avatar
Real Name: Chris
I used this video as reference along with pertinent FSM pages. Was a huge help! Love not smelling oil burning anymore. I bought the ISHINO kit off amazon cause it comes with All the seals.
I will be using your LCA bushing replacement video next. White lines read to go!
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
AZBub is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 06:02 PM #7
That hose goes to the driver's side head (no valve on that one). So, maybe a little more blowby than you want, or the stock PCV valve is blocked. That hose should be a two-way street, depending on engine operating mode (sometimes it is a fresh air inlet to clear the crankcase, sometimes it is a vent to let out extra blow-by, depending on throttle position, etc.). Make sure the hoses are in good shape, clean it up, replace the PCV valve and see where it goes from there.
Oil Leak - Valve Cover? legokcen 3rd gen T4Rs 8 01-21-2015 05:02 PM
Valve cover leak? moist_lapdog 3rd gen T4Rs 9 04-23-2014 11:03 PM
97 Valve Cover Leak Bishard 3rd gen T4Rs 9 04-27-2013 01:51 PM
Valve cover leak ? stlfan 3rd gen T4Rs 4 12-31-2011 02:16 PM
Valve Cover leak Q michealmyers 3rd gen T4Rs 0 04-09-2006 08:56 PM
