Old 07-25-2020, 12:33 AM #1
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Buying after market
Would you buy an after market alternator from Amazon for $98 USD (supposed to be totally new) OR would you pay the $278 that the Toyota dealer wants?
Traveler74 is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 01:52 AM #2
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Neither. I'd buy the denso reman from rockauto for around 125$. Or I'd buy a parts store alternator with a lifetime warranty.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 02:08 AM #3
ambush ambush is offline
ambush will become famous soon enough
Im with Underfire. OEM is the way to go. You are better off checking with Rockauto or go to SALVAGE YARD. I have replaced many remans on other folks cars that only last a few months then they call me again. REMAN run away.
If money is not really an object check out the CADDY CS upgrade or hi-output version....
Just my 2 cents
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 02:25 AM #4
Fern's Avatar
Fern Fern is offline
Fern will become famous soon enough Fern will become famous soon enough
Fern's Avatar
Salvage yard or OEM. But I've heard OEM parts sometimes aren't the same quality as what comes on a new vehicle.
2005 4R V8 4x
Fern is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 03:33 AM #5
RockAuto has a NEW A.C. Delco alternator for $154
and a Denso reman for $144 minus the core $34
Old 07-25-2020, 04:01 AM #6
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
I bought one of the new ones for my Saturn and have around 30k miles on it so far.
Old 07-25-2020, 05:55 AM #7
It was from DB Electrical and I’d do it again.
Below is a new unit.
If I ever upgrade to the GM Alt I was going to purchase it from these guys.
Old 07-25-2020, 09:07 AM #8
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
If that's $278 for a new Denso, not bad. Remember that is $278 for a part that generally won't cause trouble for 20 years.
Old 07-25-2020, 02:04 PM #9
3bears 3bears is offline
Real Name: 3 Bears
3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold
Real Name: 3 Bears
agree, 278 for a new toyota denso one, Id do that.
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 07-25-2020, 07:32 PM #10
I just bought my 1996 T4R with 195 K miles, and I'm not yet convinced that I'll even be keeping it.
In addition to the alternator problem, I also had the dreaded "check oil idiot light" come on, one day after I changed the oil to 10W-40 (to help pass smog test) and a new oil filter (from Auto Zone, not a genuine Toyota filter). I'll be changing the oil to 5W-30 AGAIN, and a Toyota oil filter.
1st step: change brushes on existing alternator. (new brushes just arrived.)
2nd step" if that does not work, I'll put in another alternator. (money is a factor).
If that does not work, I doubt I'll be keeping it. Heaven knows how bad the oil problem is. Even putting in a new oil pump may be more trouble than it's worth. I don't want to even think beyond that point. Unfortunately even dropping the oil pan, to clean the oil pick-up screen, on a T4R is a huge hassle, which includes removing the timing chain.
A real shame because when I test drove the T4R, it ran like a scalded cat.
Old 07-26-2020, 07:44 AM #11
T4R2014's Avatar
T4R2014's Avatar
10W40 doesn't trigger that light. Two possibilities. Bad oil pressure sender or your engine is worn. Oil pumps generally do not fail on these. You are more likely to have an engine worn beyond acceptable tolerances before that oil pump fails.
Old 07-26-2020, 11:52 AM #12
airdreams1 airdreams1 is offline
airdreams1 is on a distinguished road
If you're going to try to change the oil get some of this stuff and run it through 1st follow the instructions to the T!
Amazon.com: Bg109 Bg EPR Engine Performance Restoration 11 Fl Oz From the Makers of 44k: Automotive
airdreams1 is offline   Reply With QuoteReply With Quote
buying , dealer , market , totally , toyota
Who's in the market for RTT's Bski22 General Discussions 7 12-11-2017 12:46 PM
OEM or after market Seiji_1113 3rd gen T4Rs 11 04-19-2013 02:44 AM
Anybody in the market for a 3rd gen? Dezert4Runner 3rd gen T4Rs 32 12-01-2011 02:34 AM
New guy in the market Cory 44 Classic T4Rs 24 05-26-2011 12:54 AM
In the market!! FCJB Classic T4Rs 1 12-11-2009 10:44 PM
