Update time:
New Bilstein 8125 in my possesion now
I need this 90 degree fitting to run it without interfering with the UCA's
I will be running Sonoran Steel's Limiting strap frame mount with:
- Kartek Quad Wrap Blue 10" limiting straps
- Trail-Gear 9/16 shank Multi-Strap Clevis mount
- Toytec's External Reservoir Mount kit
- King 3.0" ID/ 14" 650lb Springs
The additional modification I will need to make is to the misalignment spacers on the lower mount of the CO's. They are spaced out to 1.5", and if my measurements are correct 3rd Gen's have a lower mount spacing of 1.25".... No big deal, I will just shave 0.25" off of the
front misalignment in order to shift the mounting of the CO forward of the CV axle.
This is not for any particular reason, just to have a bit more peace of mind that the CV will not contact the CO.
Re-gearing finally!!!! From stock to 4.56 E-Locker will be a huge improvement for me. 5-speed + 4.56 + 4Lo = Good Times! Doing the front transmission seal from the R150F I picked up off of Car-Part.com . No current plans to run 35's... Can anyone convince me? I feel that 4.56 with 5-speed and 35's can make for some good wheeling, any opinions on 4.88? I still want decent highway speed.
