Originally Posted by eanema
Hey guys, I stripped the bolt hole on one of the 5 bolts that hold the front skid plate up. Its the rear passenger side hole. The only way I can think of fixing this is by welding up the hole, drilling and retapping.
Problem is I don't have a welder. Any ideas how I could fix this without one? I was thinking glue of some sort, but that seems cheep...
Your options are unlimited buddy... zip ties are truly your best friend but if you plan to drag it over something then tap it to a bigger size and throw a bolt through the existing hole. If that hole isnt going to hold a new bolt then drill a new hole in the skid and make a new mounting point and your done. Don't overthink it.
Personally I would zip tie it and order a new skid that is actually going to protect you in the rocks. The OEM skid is better than nothing but it is thin and will bend upon impact if you don't already know.
