Thread Tools Rating: Thread Rating: 30 votes, 4.83 average. Display Modes
Old 10-19-2021, 05:06 PM #1021
ML Patriot ML Patriot is offline
ML Patriot is on a distinguished road
4 Wheel Drive Not Working
Hey guys,
I had my '02 4Runner lifted and now the 4 Wheel Drive will not work. Is it possible these 2 things are connected?
TIA
Matt
ML Patriot is offline   Reply With QuoteReply With Quote
Old 10-20-2021, 07:54 PM #1022
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Valve Clearance Inspection and Adjustment (3.4L 5VZ-FE)
Old 10-20-2021, 08:03 PM #1023
Sir_LR Sir_LR is offline
Sir_LR is on a distinguished road
Hello Fellow 3rd gen owners I just came home and realized something was leaking from the bottom of my 3rd gen 4runner and I went to the nearest mechanic shop and showed them and they said that its leaking from the transmission cooler lines and they listed a lot of money to do the work can somebody tell me where I can find them online and I can do the work myself and show some images on it also are they supposed to be rubber or metal
Sir_LR is offline   Reply With QuoteReply With Quote
Old 10-24-2021, 03:08 AM #1024
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you want OEM replacement trans cooler hoses, go to your local Toyota dealer parts department and order them. If you're ok with aftermarket, go buy some 3/8" transmission hose at an auto parts store. They sell it by the foot so measure what you need and have them cut you off a section.
Old 10-27-2021, 07:29 PM #1025
96lmitedrunner 96lmitedrunner is offline
96lmitedrunner is on a distinguished road
My 96 4x4 has the AT/P light when I put in park has anyone had this ?
96lmitedrunner is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 10:53 PM #1026
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Just a little Raptor Light Action.
3rd Gen T4R DIY Maintenance, Repair and Modification Videos-polish_20211028_214854793-jpg
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 12:39 PM #1027
psyduck psyduck is offline
psyduck is on a distinguished road
My passenger side window keeps getting stuck open about 40% of the time. It works at random times. Sometimes I need to hold down the button for a few seconds before it starts rolling if it does at all. Usually I just wait like 5 minutes and try again and it will work randomly. It's not the switch since it doesn't respond on the passenger door either. Only info I have found is regarding the rear window.
psyduck is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 01:42 PM #1028
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
HAHA - going all in!
Old 11-02-2021, 02:23 PM #1029
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Sounds like the window motor is getting weak. You can either replace the window regulator/motor assembly or try lubing the window tracks with silicone spray.
Old 12-07-2021, 05:49 PM #1030
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Marlin Crawler Dual Transfer Case Install (Part 2 - Installation)
Old 01-08-2022, 03:37 AM #1031
patrick28x patrick28x is offline
patrick28x is on a distinguished road
Great thread guys!! Lovin all the support videos
patrick28x is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 01:38 PM #1032
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
How to Check Lower Balljoint Play with a Dial Indicator
Old 01-19-2022, 02:03 PM #1033
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Originally Posted by mtbtim View Post
Nice to get some objectivity into the LBJ question. Thanks Tim and Sean.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 02:10 PM #1034
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Thanks Tony.
Old 02-01-2022, 10:22 PM #1035
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Transmission Cooler Install (Brackets and Bypassed)
3rd gen 4runner , mods 3rd gen sr5 , 3rd , gen , t4r
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
videos conchbuggy17 3rd gen T4Rs 1 10-03-2012 10:47 AM
Anyone need any how-to videos? knightsfs4 4th Gen T4Rs 19 08-07-2011 03:08 AM
New videos 4Funnr 5th gen T4Rs 7 10-31-2009 12:50 AM
Videos BlackIceWAP 3rd gen T4Rs 9 11-21-2005 03:41 AM
