Old 05-23-2019, 12:58 AM #166
AZBub's Avatar
AZBub AZBub is offline
Real Name: Chris
AZBub will become famous soon enough AZBub will become famous soon enough
AZBub's Avatar
Real Name: Chris
AZBubs poor man build and budget Adventures.
So I had 10 days off with the plan to be off pavement from the valley to Flagstaff for the expo but as usual adulting got in the way and a $500 vet visit kind of out a damper on plans. Instead I took the opportunity to do some maintenance.
Added Dif spacer finally.
Replaced driver side CV (will reboot OEM Toyota one at a later date)
Replaced driver side UBJ.
Added longer front sway bar links.
Added Eibach front springs.
The Eibach springs went on existing Tundra 5100s. Much smoother ride than what I had on there before and I got about an extra inch of lift. I’m almost at 23” which is the sweet spot.
I’m waiting for some OME 861s and some Bilstein resi shocks for the rear suspension to show up in the mail. TAKING FOREVER!
Provident Pathfinders on Instagram: “Doing the Ultra efficient low friction floating driveline mod. Adds 101.6 HP. Just kidding. Replacing a CV and getting a ball joint…”
By the way, if you EVER want to deal with coil springs I HIGHLY recommend the compressor below. It makes it so easy and safe. Plus you can put it on the rear springs in place once you remove your spare tire. No more having to finagle them out using catawompus methods.
Provident Pathfinders on Instagram: “Ohhh totally awesome coil spring compressor, where have you been all my life!?!? You make swapping front and rear springs a breeze!…”
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
AZBub is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 09:57 PM #167
Bandit Runner's Avatar
Bandit Runner Bandit Runner is offline
Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough
Nice update! I hope you’re pet is doing well.
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
Bandit Runner is offline   Reply With QuoteReply With Quote
Old 05-24-2019, 01:43 AM #168
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
I sure hope so. He is a 9 year old great dane. Somehow he got a bone infection in one of his toes and antibiotics for bone infections are $$$. I hope to take him on a trip in the 4runner again soon. For such a big oaf of a dog he loves off-roading.
Old 05-28-2019, 11:18 PM #169
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
So one more piece arrived today.....
OME 2861’s. Got tired of riding bump stops on multiple owner, tired FJ80 springs. I like the stance my runner has now. A little bit of rake is good with me.
The first one was a PITA to swap out, but it was totally my fault....if you look closely at the first pic you should see why. The other side took all of 10 minutes once the tire was off.
Tomorrow, another piece shows up, if FedEx gets their ish together.
Old 05-29-2019, 06:30 PM #170
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
Final parts have shown up. Going to wait till the weekend to install them.
Thinking about the PCK from Eimkeith....
Old 06-20-2019, 12:01 AM #171
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
https://www.instagram.com/p/By6tM9Ng...=165likao1n0rp
Old 06-20-2019, 05:02 AM #172
jspiv jspiv is offline
jspiv is on a distinguished road
Love the build man! Never been a fan of rear storage build-outs, but yours is super clean and making me want to look into it!
2002 4Runner 13x,000 miles
Denver, Co
jspiv is offline   Reply With QuoteReply With Quote
Old 06-20-2019, 07:30 AM #173
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
Thanks, it was a lot of work but really helps organize all the gear and what not. We use it every day actually.
Old 06-21-2019, 09:19 AM #174
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
@AZBub What did you decide to go with for front suspension?
Old 06-21-2019, 05:45 PM #175
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
I’m still running Tundra 5100s, I just updated them to new Eibach springs. Probably going to go 6112 next year some time.
Old 06-22-2019, 07:32 PM #176
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
By chance do you have any, or could you take a couple, close up photos of how you mounted your roof rack?
I've got the same set up, but have it on the factory cross rails at this point. I'd like to mount it directly to the rails but the rack is about a half inch narrow.
I really like the way yours looks and would like to replicate.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 06-22-2019, 11:54 PM #177
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
I pretty much used this thread for the build. Inexpensive Full Length Roof Rack (Curt Rack)
Old 06-23-2019, 05:56 PM #178
Real Name: Ryan
Real Name: Ryan
Yeah, I did the same and wasn't happy with it. Your's looked to be done different. No worries!
2001 BMW M5
Old 06-23-2019, 07:20 PM #179
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
yeah so the Curt rack doesn’t line up well so you have to angle the holes. Was a PITA. the front feet i used were some industrial stainless steel furniture feet. Found them on Amazon. Also getting the right angle so the rack follows the roof line is difficult as it’s done with stainless washers. Still, waaaaay cheaper than what’s on the market for a basket type rack.
Old 07-10-2019, 03:05 PM #180
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
Got out of the heat and headed norte to the mountains.
Provident Pathfinders on Instagram: “The best time to camp is AFTER the holiday weekend. Deep in the woods, rain and hail and a cool 67 degrees. Beats the 108 in the valley.…”
Provident Pathfinders on Instagram: “Two nice Rainbow trout in the 12-14”range out at Black Canyon lake today floating natural scent garlic Powerbait about 3 feet off the…”
Provident Pathfinders on Instagram: “The cool breeze of Anytown USA.... In this case Forest Lakes area. Black Canyon lake.
@azgfd #arizona #arizonafishing”
Provident Pathfinders on Instagram: “Night moves.
#3rdgen4runner #toyota #toyota4x4 #toyota4runner #arizona4runners”
Provident Pathfinders on Instagram: “Wild horses were everywhere up on the rim. Forest Lakes AZ. #arizona #arizonatrail #arizona4runners #3rdgen4runner #arizonawilderness…”
Tigger's Build and Mis-Adventures tigger 5th gen T4Rs 140 05-07-2022 09:55 PM
Adventures of 4RnR Grl (and build) 4RnR Grl 5th gen T4Rs 451 06-27-2021 11:57 PM
The Overland Adventures - 4th Gen Build! fo' runnin' 4th Gen T4Rs 179 10-02-2018 09:46 AM
Stillbreathn - Build and Adventures Stillbreathn 5th gen T4Rs 24 11-27-2016 09:49 PM
The Build & Adventures of Valken Dane2992 5th gen T4Rs 0 04-20-2016 01:51 AM
