Old 05-14-2016, 10:51 PM #1
denvermaxd denvermaxd is offline
Real Name: Max
denvermaxd is on a distinguished road
Real Name: Max
Rear Main Seal - Replacement Has a Gasket?
2000 4Runner SR5 3.4 5-speed manual...
I'm in the middle of a clutch replacement, and had decided to do the rear main while I'm in there.
I ordered a Fel-Pro gasket from Amazon, and it comes with a gasket:
When I removed my rear main today I noticed there is no gasket. My Haynes manual makes no reference to using a gasket, just RTV gasket maker (which I purchased and have on hand).
Question: Should I just discard the gasket? Or is this some improvement on the stock implementation?
2000 4Runner SR5 5-speed manual e-locker, 231mm Tundra brake upgrade, OME 881/890 Suspension, Stubbs Rock Sliders, TRD Supercharger
2022 Highlander
2002 Dodge Ram 1500
denvermaxd is offline   Reply With QuoteReply With Quote
Old 05-14-2016, 11:54 PM #2
nobb nobb is offline
nobb is on a distinguished road
I used a Victor Reinz rear main seal which came with a paper gasket. I threw away the gasket and just used RTV. RTV seals better against surface imperfections and remains more pliable over time whereas some gaskets get old and crusty. Also with the rear main, you'll have to use RTV on the bottom edge contacting the oil pan anyways.
nobb is offline   Reply With QuoteReply With Quote
Old 05-15-2016, 10:09 AM #3
Real Name: Max
Real Name: Max
one thing leading to another...
My own research on this revealed a significant number of thread where folks experienced leaks within days of installing non-OEM (several Fel-Pro) gaskets.
The transmission pull and clutch removal is such a PITA, I have decided to wait for the dealer to open tomorrow and pick up a Toyota OEM rear main seal.
It's just not worth the anxiety and (added) potential for failure when I'm doing it myself.
2022 Highlander
2002 Dodge Ram 1500
Old 05-15-2016, 11:26 AM #4
01thunder's Avatar
01thunder 01thunder is offline
Real Name: Ivan
01thunder is on a distinguished road
01thunder's Avatar
Real Name: Ivan
The main seal retainer doesn't need to come off. Just replace the seal.
2001 SR5,
thundercloud, tundra brake upgrade with 231's, 906's/billies rear, 5100's/stock coils on 4th groove front, ISR/deck plate mod, ford trans cooler mod, 99-00 grille swap, led conversion, 17" 2014 SR5 wheels wrapped with cooper AT3's, 265/70/17
01thunder is offline   Reply With QuoteReply With Quote
Old 05-15-2016, 11:40 AM #5
It's a large seal and it's easier to get a straight fit if you take the retainer off and press the seal while off the engine. The sealant on the retainer is old and stiff so you might as well replace that while you're in there.
Old 05-15-2016, 01:20 PM #6
Real Name: Max
Real Name: Max
Yeah... it's already off.
The RTV I have is Permatex Gear Oil RTV Gasket Maker. Is this appropriate to this application? Or should I use something else?
2022 Highlander
2002 Dodge Ram 1500
Old 05-15-2016, 01:34 PM #7
No, that's for differentials. You should be using the black one...Permatex Ultra.
Old 05-15-2016, 01:57 PM #8
Real Name: Max
Real Name: Max
Probably saved me some trouble. I'll go grab the Ultra.
2022 Highlander
2002 Dodge Ram 1500
Old 05-15-2016, 02:30 PM #9
01thunder's Avatar
Real Name: Ivan
01thunder's Avatar
Real Name: Ivan
or the gray. it is similar to the factory one. that is all i use.
2001 SR5,
Old 05-15-2016, 04:04 PM #10
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
Why not use the best: Toyota FIPG Especially on such a critical area?
Rear Main Seal - Replacement Has a Gasket?-71gk5ivdqol-_sl1500_-jpg
'96 T4R SR5 V6 Auto 2WD 329,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 05-15-2016, 06:05 PM #11
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
I wonder if there's a difference in the Toyota F.I.P.G material because...
pn# 0029500103 comes up as F.I.P.G for oil pan
pn# 0029501281 comes up as F.I.P.G for trans pan
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 09-03-2016, 09:44 AM #12
jstim's Avatar
jstim jstim is offline
Real Name: Josh
jstim is on a distinguished road
jstim's Avatar
Real Name: Josh
Going to resurrect this thread since I have some questions and I don't want to start a new one.
When doing the rear main seal it would obviously be a horrible idea to use a paper gasket like that. Now with that said, if you put the FIPG on where it bolts together. Who's to say it's going to line up perfect the first time? Or is there a way to make sure it does so that when the engine and tranny are pressed together that it all lines up just right.
1999 Toyota 4Runner SR5 - Icon CDCV 2.5's, SCS Matte Black SR8 wheels, Audio overhaul (Alpine CDE-HD149BT, Kicker CS65s up front and CS5s in back
My build thread:http://www.toyota-4runner.org/3rd-ge...ack-pearl.html
2015 Toyota 4Runner Trail Premium traded for 2015 Ford F-250 Super Duty
Originally Posted by StreetCreeper View Post
And you also tell him that right before Absalom smokes them on the trail—he skins them first and fashions their dirty lifeless hides into camp-hats to keep warm at nite...
jstim is offline   Reply With QuoteReply With Quote
Old 09-03-2016, 11:20 AM #13
bentos1's Avatar
bentos1 bentos1 is offline
bentos1 is on a distinguished road
bentos1's Avatar
Take a look at this pic of a rear main seal, you can see the FIPG around the edges. There is no issues with the transmission and engine mating when doing this job.
I just replaced mine when I installed a new clutch kit and did not replace with a Toyota gasket. Fingers crossed that I dont have any issues. I did not take the retaining plate off. I used a wood screw in the seal and then pulled out the seal, no bolts were disturbed. You can just press in the new seal afterwards. I used a bit of grease on it for an easier install, once again I hope this doesnt cause issues
1997 4Runner 5 Speed E-Locker
bentos1 is offline   Reply With QuoteReply With Quote
Old 09-03-2016, 01:36 PM #14
jstim's Avatar
Real Name: Josh
jstim's Avatar
Real Name: Josh
The job itself seems pretty easy then. Its just the pulling the entire tranny out just to get to it. That kind of sucks, but I guess you have to do it.
Old 01-02-2017, 04:23 PM #15
jstim's Avatar
Real Name: Josh
jstim's Avatar
Real Name: Josh
Does anyone have the part number for the rear main seal? I want an OEM rear main....and do I need anything other than the rear main seal?
Edit: Here is the OEM Rear main seal part number :90311-A0027
Rear main seal housing gasket voiddweller Maintenance/Detailing 0 06-11-2015 06:05 PM
Rear Main seal/Head gasket repair or save my money for a new 4runner. 4runnerV6 4th Gen T4Rs 18 01-14-2015 01:43 PM
Rear Main Seal or Oil Pan Gasket Leak Squintoo 3rd gen T4Rs 6 04-14-2014 05:22 PM
Rear Main Seal Replacement V6 MtnBrook 4Runner 4th Gen T4Rs 0 03-15-2014 07:32 PM
Rear main seal replacement KidVermicious Classic T4Rs 4 10-25-2012 06:46 PM
