07-18-2016, 01:50 AM
#16
Originally Posted by kolelt
My truck pulls to the left when breaking. Is that sign of bad LCA bushings?
I have the same problem. I've replaced LBJs, ITREs, OTREs, coilovers, and steering rack bushings. I still have the original UBJs with 270k, so I'm not 100%. I think my problem is narrowed down to LCA bushings, maybe yours too.
I have a 9" body lift.
Shooter's Build
07-18-2016, 06:41 AM
#17
Originally Posted by MandAtaco
Mine would align, but pulled everywhere. I replaced the one bushing and truck is solid again. The other 3 have over 200K on them now.
Yeah mine would "align" but wouldn't hold it when it was put back on the ground.
Sent from my SM-G935V using Tapatalk
**2007 4runner Limited 4.7L V8 4X4**
Bilstein 5100s, 275/70/17 BFG KO2s, 5000k VLEDS (headlights & interior),HCF Delete.
07-18-2016, 06:42 AM
#18
Originally Posted by JayRolla
Yeah those aftermarkets are worse than worn oem bushings. I installed polys. Still the best thing I've done to my truck. Solid now.
I'm thinking about doing polys on my uppers!
07-18-2016, 06:44 AM
#19
It's a very good chance. Mine wasn't pulling all that bad with worn oem bushings. These after markets are terrible and causing the truck to pull hard right.
07-18-2016, 07:13 AM
#20
Real Name: Charlie
Real Name: Charlie
Even after proper alignment?
I swapped mine out for Poly bushes a few years back, it did feel sharper, (Compared to old factory fitted parts) but I've since decided to swap and get a brand new factory lower arm.
I think I'm going to replace the rear with factory too.
07-18-2016, 07:25 AM
#21
I think I'm going top replace the rear with factory too.
Yes even after alignment it still was not fixable!
07-18-2016, 12:15 PM
#22
Worn out Bushings could cause that, I would also check to make sure you don't have a brake caliper hanging up or dragging. I've heard even a hanging rear brake could cause a pull.
Yea, my bushings aligned fine, drove down the road straight, but as soon as I hit the brakes, it would change lanes on me.
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
07-18-2016, 12:40 PM
#23
I did my LCA bushings over the winter and it was a hell of a job. Alignment bolts seized, unbolting the steering rack, pressing out then in the new OEM bushings. Took a solid 10 hours and I never even got to the uppers. They are still sitting in my office.
However it was well worth it. The loud squeaking is gone. Truck feels brand new.
My only issue now is when I hit bumps at speed, the front seems to rattle. I'm thinking, well hoping, that it's either my front shocks just worn out or the uppers control arm
bushings
1999 Highlander Edition, Imperial Jade Mica, Auto with e-locker, OME 906s Rear with Bilstein 5100 shocks, 5100 with OME 880 fronts, Airaid Intake, Custom cargo basket with Quickfists. Lots of mechanical 241,000+ miles
Follow the Adventure on Instagram: http://www.pictaram.com/user/twistingterrian/3486826971
07-18-2016, 02:19 PM
#24
bushings
I was looking at eBay you can used LCA for 60 a pop. And replace the bushig then and just a wrap the LCA. Rather then have your truck sit there on jacks.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
07-18-2016, 02:51 PM
#25
You can also find good used parts on Japanesetruckdismantling.net as well!
07-18-2016, 03:22 PM
#26
I'm about to tackle this same job with my '99 4Runner SR5. Not looking forward to it. I went the way of the junkyard, purchasing two spare LCAs and then I bought new OEM bushings to go in both of them.
I'm going to purchase new steering rack bushings also and change all that out at the same time. I have the goal of using the Camburg Racing UCA's at some point so I'm not going to worry about changing those out just yet.
'99 Millenium Silver Metallic | Factory E-locker | 5 speed | King 2.5 Coilovers | King Rear Shocks W/Resis | LC 7.5 Rear Springs | 231 Tundra upgrade | ES Steering Rack Bushings |
07-18-2016, 04:35 PM
#27
Be sure to look up Timmy the toolman on YouTube. It will make your job much easier. He explains in great detail!
07-18-2016, 06:18 PM
#28
Real Name: Jordan
Real Name: Jordan
Don't need to drop the rack when pulling cams. Just need to remove the mounting bolts for rack, and position down about 1", and out of the way.
I'd recommend only OEM LBJ's, and poly LCA bushings. Heat the LCA's just outside the bushing with a propane torch until you hear a pop. Then push out with a flat-head. Messy, but easy job.
Don't be scared of this job. New LCA bushings will dramatically change the way your truck handles. If you have over 100k miles, change em now. Text me @ 480.779.8307 if/when you get stuck.
07-18-2016, 09:49 PM
#29
Originally Posted by absalom
... and poly LCA bushings.
The LCA bushing thing is confusing to me. Seems like half the forum goes OEM and the other half goes poly.
07-19-2016, 06:12 AM
#30
Yeah it seems that way. The only real negative I've read most about the polys are the squeaking. I'm a firm believer in OEM though.. there's a reason why it last over 200k miles the first time!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
DAC removal
crashman |
4th Gen T4Rs |
2 |
12-12-2014 02:29 AM |
tie rod end removal
Scraptrooper |
Classic T4Rs |
3 |
04-27-2014 11:38 PM |
CV removal
spongerx |
Maintenance/Detailing |
4 |
01-14-2012 12:00 AM |
Tar Removal
tomhaney1 |
23 |
12-29-2008 11:16 PM |
HU removal in a 2k4
NervusPSU |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
4 |
01-04-2005 05:21 PM |
