Old 09-20-2006, 11:15 AM #1
Orion Orion is offline
Orion is an unknown quantity at this point
Thumbs down Broken/seized skid plate bolts
What is the easiest way to remove these broken/seized bolts? This pic isn't from my truck but it's a good illustration of the same problem I'm facing. Actually 2 of the 3 bolts which hold up the front end of the skid plate are like this. The bolt head is sheared off with the remaining threaded portion still stuck in the hole. I recently bought the vehicle and just noticed this now. If I can somehow remove them I will definitely apply some antizseize compound on the new threads, generally it seems a bit rusty in the vicinity. I'm a bit nervous with only the 1 bolt holding up the front of the skid plate.
Broken/seized skid plate bolts-skid_plate1-jpg
Orion is offline   Reply With QuoteReply With Quote
Old 09-20-2006, 01:57 PM #2
GSGALLANT GSGALLANT is offline
GSGALLANT is on a distinguished road
You could try a bolt extractor, but if they broke, they are probably seized in there pretty good. The easiest way is just to drill them out (appropriate size for the tap you'll need to retap the hole), then run a tap through to clean up the threads. If you mess it up while drilling, you can always go up to the next size bolt.
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline   Reply With QuoteReply With Quote
Old 09-20-2006, 02:12 PM #3
lee's Avatar
lee lee is offline
lee is on a distinguished road
lee lee is offline
lee's Avatar
yup
you could also try vice grips, see if you can grip that last one.
2006 4Runner Sport 4wd
XREAS
JVC kw-nx7000 head unit
lee is offline   Reply With QuoteReply With Quote
Old 09-22-2006, 10:59 PM #4
ohio4runner4x4's Avatar
ohio4runner4x4 ohio4runner4x4 is offline
ohio4runner4x4 is an unknown quantity at this point
I had the same problem and did exactly this.....and when you re-install it.....make sure you coat it real good with anti-seize!
2000 4Runner Limited 4x4
2001 Sequoia Limited 4x4
ohio4runner4x4 is offline   Reply With QuoteReply With Quote
Old 09-23-2006, 12:44 AM #5
gapboi210's Avatar
gapboi210 gapboi210 is offline
gapboi210 is on a distinguished road
gapboi210's Avatar
By the way. That is not the only bolt holding it up. There are 2 larger bolts in the middle recessed in too.
'98 4Runner Limited 4x4
gapboi210 is offline   Reply With QuoteReply With Quote
Old 03-14-2011, 10:47 AM #6
01SR5VB 01SR5VB is offline
01SR5VB is on a distinguished road
ive got the same damn problem
mine is the same way...i really cant believe its so bad.
01SR5VB is offline   Reply With QuoteReply With Quote
Old 03-14-2011, 11:24 AM #7
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
I'd start by drenching them in PB Blaster. Use a straw nozzle to direct the goods through those holes so the threads get the benefit from the top down. Let it work, don't force them...
They might be too far gone already, but if you can coax them out it'll beat trying the drill/extract/tap method which is bound to end in fail.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 03-14-2011, 12:14 PM #8
MrBobDobalina's Avatar
MrBobDobalina MrBobDobalina is offline
MrBobDobalina is on a distinguished road
If you have a small propane torch, you can heat up the area and use a bolt extractor with ease.
MrBobDobalina is offline   Reply With QuoteReply With Quote
Old 03-14-2011, 12:26 PM #9
JohnsD90's Avatar
JohnsD90 JohnsD90 is offline
JohnsD90 will become famous soon enough
JohnsD90's Avatar
Mine is only held one by bolt on the front, ive taken mine through hell and back in these snow and icestroms too. It's had 1 bolt since i got it, and when i put my new skid on installed with 1 bolt again, works great.
JohnsD90 is offline   Reply With QuoteReply With Quote
V-8 skid plate mod for oil filter change loner Maintenance/Detailing 16 12-31-2023 09:01 AM
Skid Plate Bolts J.A. 4th Gen T4Rs 39 06-30-2018 10:57 AM
Need Advice on Repairing Broken Skid Plate Bolts rjaudi 3rd gen T4Rs 2 06-05-2010 03:31 AM
rusted skid plate bolts nc211 4th Gen T4Rs 7 12-20-2008 11:07 PM
Factory Skid Plate Removal, how many bolts? Recoil Rob 3rd gen T4Rs 1 08-26-2007 10:47 PM
