I did search and read thru a few threads to try to find an answer. See thread link below,
Picked up a set of 16x7 06 Tundra 18 hole black steel wheels to run thru the winter so I can sand down and paint my 5 stars properly over the winter.
Got a set of proper lugs for the wheels as well.
Went to get them mounted today a local shop and the mechanic could not get them to balance at all.
Noticed that when the cone is put in the OEM's it sits flush, but the steelies have a lip and did not sit completely flush, This was on all 4 . Got one to finally balance but the problem persisted with the others so I decided to remount the OEM's, which re balanced fine, and try to figure this out.
Steel wheels are in good shape, low miles on them.
The thread that seemed to give the most info is this one
Haweka Adapter
Do I need to find a shop with a Haweka adapter to make this happen. ?
The guy doing knows his stuff and could not figure this one out and was cool and did not charge me .
Thoughts ? Ideas ?
Thanx for taking the time to read this,
