10-23-2016, 06:23 PM
Is it too late?
Hey guys...long time lurker here,
Twice a year I camp/off road in Uwharrie National Forest and after each trip I get the bug wanting to lift my 4Runner. Of course I just got back from my trip and the desire is stronger than ever. I have a 2001 that I've owned since 2004 and it has 245k miles. The front struts are needing to be replaced so before I do that I'm wanting to weigh my options and get some opinions on what I should consider before moving forward with a lift.
I feel like my 4Runner is in good shape, regular maintenance has been completed by my brother in law's shop. Other than the struts, there's something going on with the steering because there's a lot of play (haven't figured this out yet). It's not my daily driver but i would like to sell my car and go back to this.
Orginally I was looking at the cheaper route with the Rough Country option because my lift will mostly be for looks with 3 or 4 trail trips a year. Ive since started looking at the Toytec/Bilstein or "complete OME" lift options because I'm not too excited about spacers on the front.
Couple of questions:
Have I waited too long? Are there too many looming problems at 245k?
How silly would a 3rd gen look with a 3 inch lift while still running 265/70/16s? I just got a great deal on some Kuhmo AT so I'd like to lift my 4runner and upgrade to 285s once these wear out. Online pictures don't seem too bad but I've never seen this set up in real life so how does it look?
Is regearing needed with 285s. Is this something I should even consider at 245k miles?
I'm basically a mechanical newb so I apologize in advance for any stupid questions.
Thanks!
10-23-2016, 06:45 PM
Real Name: Just call me the Grease Monkey
Your front play may be the lower ball joints, lift up the front and wiggle the wheel to look at the play.
10-23-2016, 06:47 PM
Just do it
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
This is my 02 with a 2" lift ( 5100s & ome ) with 265/70/16 Grabber at/2s. Sorry about the upsidedown pic.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
10-23-2016, 07:07 PM
Real Name: Woody
Real Name: Woody
So everybody doesn't have to rotate their phones ... or heads.
"Variety is for your mind, not your body " —OS
10-23-2016, 07:31 PM
Thanks. I saw a thread last week about a recall for the 01 and 02's on the lower ball joints so I should look into that.
10-23-2016, 07:34 PM
I really like that look, that settles the question about the 265's. Thanks!
10-23-2016, 08:20 PM
Thank you.
Vietnam 67-68
10-23-2016, 09:05 PM
RedSled, have you measured that lift? It looks like a lot more than 2" in the rear. Mine looks like that and I gained about 5" in the rear.
I have a 9" body lift.
Shooter's Build
10-23-2016, 09:10 PM
as far as its mileage. this will break and things will fail as you use it. Question is are you A: willing to be ok with the expense of stuff breaking. and B: Cool with fixing it yourself or paying to have it fixed.
For me. I dont wheel, but if something break I fix it. I like working on trucks and cars. So for you, the question becomes, "do you like turning wrenches?" BC if you lift a 4runner, you will always turn wrenches.
10-23-2016, 09:26 PM
Real Name: Jordan
Real Name: Jordan
Thanks!
The answers to all of your questions lie here.
10-23-2016, 10:49 PM
Real Name: Doug
Real Name: Doug
This Spring, I replaced my front and rear suspension. It was time, as the rear was sagging and the ride had really become hard. I replaced the rear with OME906's and fronts with OME880's all with Rancho 9000XL adjustable shocks. This resulted in roughly 2" lift. The ride is 1000% better but I probably would have gone for Bilsteins if I had to do this again--- The Rancho's are fine but they are supposed to be adjustable and I notice little difference between 1 and 9, these Ranchos were approx. 15% more $$.
http://www.toyota-4runner.org/3rd-ge...0707-04004.jpg
As far as the steering issue is concerned, I've done a number of things over the last few years to reduce the play in the steering. First thing, I replaced the rack bushings, then LBJ's after I discovered the dangerous failures members have experienced. They tested ok but when I replaced them, they were pretty rusted! I replaced TRE's , sway bar bushings and checked all other suspension components. I Then replaced the rack guide and after each component change, I experienced a slight improvement. The steering is acceptable now, but if I was going with larger tires I'd probably look at a few other components ie. steering shaft joint, and the rack.... I'll admit when its time to change tires, I may go slightly bigger--- my Winters are 265 70 17 mounted on 17" Sequoia rims.
1998 SR5 3.4L V6 Auto... Pretty much bone stock...aside from the Tundra brakes, OME880 and OME906's in back all with Rancho 9000XL adjustable shocks ... "Livin' the dream in the Canadian Okanagan!"
Electronics/Telecommunications Engineering Technologist
10-24-2016, 12:47 AM
my '99 is lifted, right at 225k miles, and i daily it. go ahead and lift it!
1999 Limited
Overland build in progress
10-24-2016, 09:21 AM
Well the plan would be to sell my C300 so that would free up a good amount of cash each month I'm already spending on a vehicle. As long as this project doesn't cost more than $500/month on average I'll be coming out ahead (famous last words right?). I don't mind getting my hands dirty but I don't always trust myself to get a mechanical job done correctly haha. I figure there are plenty of forums or how to's for any problems plus my BIL tends to cut me a great deal on labor. Thanks for the response!
10-24-2016, 09:43 AM
Thanks. I'll probably start with the LBJs and work through like you did. There's always been some play in my steering and I'm hoping some is from the worn out suspension. I replaced the rear shocks with a cheap option recently and I couldn't believe how much the ride quality improved so I'm excited to see what a quality upgrade will do.
