Old 10-31-2016, 01:41 AM #1
mendozer mendozer is offline
mendozer is on a distinguished road
Bed Liner for my rig
I'm tired of looking at my flaky clear coat. I thought about coating the whole rig in a bed liner because:
- it's rugged
- I don't have the time to wash and wax all the time
- it's...rugged
Any input for the DIY kits like Herculiner, Al's, LinerExtreme, SprayLinings, or Raptor?
mendozer is offline   Reply With QuoteReply With Quote
Old 10-31-2016, 02:35 AM #2
MN4runnerman's Avatar
MN4runnerman MN4runnerman is offline
Real Name: Samuel
MN4runnerman will become famous soon enough
Real Name: Samuel
I used a gallon of Black Raptor brand Bed liner to do the interior of my jeep. 6 years later I only had to touch up the spot were my feet are next to the pedals. Everything else is great. I'm gonna get a can of the tintable bed liner they sell so I can paint some sliders and an ARB bumper I have to match my 99.
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
MN4runnerman is offline   Reply With QuoteReply With Quote
Old 10-31-2016, 02:38 AM #3
I'd trust myself to do a better job with spray applications vs rolling. Tape everything off then spray away. I'd assume it's easier to get even. So you took out any carpeting and had a lined interior?
Old 10-31-2016, 02:44 AM #4
Real Name: Samuel
Real Name: Samuel
Yeah what was left of the carpeting. I used a roller and it turned out pretty good in there, there's no monster globs or anything it looks pretty even. For the sliders and bumper that I'm gonna do I was thinking of spraying them just cuz I can and then compare.
Edit: @absalom posted a thread awhile ago of him and his buddy using monstaliner on his buddies 3rd gen. I thought it turned out pretty good.
Old 10-31-2016, 03:51 AM #5
DLM_2002's Avatar
DLM_2002 DLM_2002 is offline
Real Name: Dan
DLM_2002 is on a distinguished road
DLM_2002's Avatar
Real Name: Dan
Upol makes a nice 2K (paint with hardener) spray on kit. I just did the bottom half of my rig with it. I did my front bumper a little while back. Only thing that sucks is it has a 5-7 day full cure time. They do have colors to so you dont just have to do black, but stay away from tintable.
This is the 8 quart kit, i did my lower half and front and rear bumper with 4 quarts.
https://www.amazon.com/U-POL-Raptor-...l+raptor+liner
DLM_2002 is offline   Reply With QuoteReply With Quote
Old 10-31-2016, 08:06 AM #6
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
- it's rugged
- it's...rugged
check this out
absalom is offline   Reply With QuoteReply With Quote
Old 10-31-2016, 09:23 AM #7
Real Name: Samuel
Real Name: Samuel
Why would you want to stay away from tintable? I have no experience with it yet so I just wanna know what I might be getting into.
Old 10-31-2016, 09:34 AM #8
DLM_2002's Avatar
Real Name: Dan
DLM_2002's Avatar
Real Name: Dan
All the reviews i have read said it doesn't tint well and the color doesn't stay. I have never tried it but that isn't something i would try without knowing it would work.
Sent from my SM-G920V using Tapatalk
1997 4Runner SR5 3.4, Elocked, Toytec ultimate, Armor
1991 Toyota Pickup 22re
Old 10-31-2016, 11:35 AM #9
ATX-Runner ATX-Runner is offline
Real Name: Josh
ATX-Runner is on a distinguished road
Real Name: Josh
Unless its a high grade UV stable tint lighter colors will yellow or fade.
99 Limited, Bilstein 5100's with OME 883's up front LC 8 wraps in the rear, LC wheels drilled for et nuts, ARB bumper and some other stuff
ATX-Runner is offline   Reply With QuoteReply With Quote
Old 10-31-2016, 11:53 AM #10
Brentif Brentif is offline
Brentif is on a distinguished road
I sprayed the whole outside of mine with Monstaliner, never did a write up though. I went the spray route, which was easy to do. The most difficult part is the prep and masking. I went two tone, as to match the existing paint. I used Monstaliner's grey, which turned out fantastic. I opted to tint my own green, and had a body shop mix some tint for me. This part turned out terrible, now it should be noted that I did not use the recommended tint. The green turned out to be a candy, basically showing all the imperfections and sanding marks through the liner. I reordered more green for the truck, and will be using their green tint for round two.
Brentif is offline   Reply With QuoteReply With Quote
Old 10-31-2016, 01:41 PM #11
elliot627 elliot627 is offline
elliot627 is on a distinguished road
I have a couple of friends that are avid gearheads and know much more than I do when it comes to cars (1 of them worked as a professional mechanic for ~5 years, and they both race autocross etc), and they both highly recommended against exterior bedliner coatings because they said once water gets in between the lining and the metal (which is fair to assume it will, esp. considering off-roading abuse), it can cause the metal underneath to rust much more easily as the water is trapped in there, and you won't know anything about it until a panel collapses.
Don't shoot the messenger... Curious what your thoughts are on this?
elliot627 is offline   Reply With QuoteReply With Quote
Old 10-31-2016, 01:49 PM #12
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
I used monstaliner around my fenders and rockers. Eventually the whole truck will be monstaliner when the original paint goes bad
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 11-01-2016, 12:45 AM #13
absalom i did see that post, came out very nice. I wonder how long it'd take mt to completely take out lights, bumpers, etc. I was thinking of this as a weekend project.
as for curing, they're talking about stressing it out like throwing toolboxes in truck beds. once it's dry to the touch you can drive it around right? I can't be without it for a week.
As for the rust issue I'd assume that if done well, water shouldn't find it's way in.
Old 11-01-2016, 08:20 AM #14
absalom's Avatar
Real Name: Jordan
absalom's Avatar
Real Name: Jordan
We did the whole project in a day, and he was driving it the next day.
Get some friends to help, it'll make an already easy project even easier.
Old 11-01-2016, 12:01 PM #15
it says you used 1 gallon of primer, how much of the regular coat? And did you add acetone to it to spray it?
First Dog. Pet cargo liner needed. Tailgate and side wheel well liner necessary? alext72888 5th gen T4Rs 24 10-03-2016 02:02 PM
Husky Liner grey cargo liner 3rd gen $50 HBG PA Hossdawson For Sale: T4R Items 4 10-09-2014 07:14 PM
FS: NEW 5th Gen Husky Liner WeatherBeater Cargo Liner TAN $60 shipped USPS shinyblackdeer For Sale: T4R Items 0 05-22-2014 07:18 PM
FS: 2010 Husky Liner Cargo Liner, Black spesrf25 Classifieds - buy & sell (no commercial ads please) 7 05-26-2011 10:04 PM
WTB: Floor Liner and cargo liner kasimo420 Want to Buy/Trade 5 02-20-2009 09:47 AM
