12-14-2016, 08:17 PM
Real Name: Josh
Real Name: Josh
Suspension....To Resi or not To Resi, that is the question!
So I added all the armor to my 99(Full Shrockworks treatment), and Radflo 2.0 no longer cuts the mustard. I know I need at a minimum a 2.5, with a 650# spring. I have and in the back of my mind am considering a 700# spring. Here is the nitty gritty, I wanted ADS, or King adjustable valving. Apparently that doesn't sound like it's an option, neither even have the remote resivoir CO. Is it worth it to have the Resi? Or should I just avoid the pain of having the Resi? I'd like some solid insight on the pros and cons. I'm going change out the rear shocks too in the next 6 months as well.
1999 Toyota 4Runner SR5 - Icon CDCV 2.5's, SCS Matte Black SR8 wheels, Audio overhaul (Alpine CDE-HD149BT, Kicker CS65s up front and CS5s in back
My build thread: http://www.toyota-4runner.org/3rd-ge...ack-pearl.html
2015 Toyota 4Runner Trail Premium traded for 2015 Ford F-250 Super Duty
Originally Posted by StreetCreeper
And you also tell him that right before Absalom smokes them on the trail—he skins them first and fashions their dirty lifeless hides into camp-hats to keep warm at nite...
12-14-2016, 08:27 PM
From what I have gathered and noticed on some rigs is the front really dont need the Resi. The rear shocks seem to fade out quicker so the resi works really well in the rear. But again, resi is always better!!
12-14-2016, 08:35 PM
Real Name: Alex
Real Name: Alex
I have nearly 3" of preload on my 650lb springs to get me 2.5" of lift. My coils aren't hitting each other yet, so I am not "springing" for the 700lb springs yet. I had them on my old coilovers and I much prefer the ride with the 650s.
My experience with Radflo is limited to
@ GSPRunner
's old shocks (2.5" body with a 2" piggyback) and I did not care for them at all. Paired with his King coilovers up front, they sure as hell were lacking.
As for reservoirs... What kind of wheeling are you into? I got them because I like to do more of the "go fast" type stuff and with my 4Runner weighing around 6000lbs when loaded for a trip, I knew I would probably want that extra fluid capacity in order to avoid shock fade.
What do you mean King doesn't have adjustable valving? I am not familiar with ADS, but I have seen adjustable Kings with my own two eyes =)
EDIT**
Really though, if you're not drastically changing your vehicle's weight, the adjustable valving is more of a luxury than anything. I stiffen mine up when I have the tent on top, heavy ass cooler, dogs, wife, etc. Soften it up when daily driving or when too lazy to air down lol.
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
12-14-2016, 08:41 PM
I have the Radflo 2.5 Resi on my '00 and found the resi's were a bit of a challenge to mount, and I ended up re-mounting the rear ones twice and the front ones 3 times. I'm glad I have the resis but I wish the Radflo resi setup was a bit more put-together like the Icon which has vehicle-specific brackets designed to mount the reservoirs instead of universal brackets.
Overall I'm glad I have the resis for the peace of mind as I know I will have no worries of my shocks fading or overheating. So if you have the finances I'd say go for it. If your budget is tight I'd say they're not totally necessary and your rig will still function capably without them.
You could also send your shocks back to Radflo and they could add resis to your 2.0's.
2000 Limited. Lifted....finally!
www.OverlandNV.com
12-14-2016, 08:55 PM
Real Name: Alex
Real Name: Alex
I imagine Icon would sell you some brackets for a very, very steep mark up haha.
Are you running Radflo coilovers too? I wonder how their "linear" valving would feel up front.
12-14-2016, 10:21 PM
Real Name: Josh
Real Name: Josh
@ GSPRunner
EDIT**
I do a lot of camping, I use it to get around hunting, I daily drive my rig a lot, and I do find myself going probably faster than I should through so fire breaks, dirt roads, stuff like that. I did not spend the money initially to get what I wanted, I went cheap with the Radflo option. It was great while it didn't have any armor on it, but as soon as I added that, I am back to my 265/75/16 rubbing on occasion now. I just want it to be right now. I want it to be fully functional, no longer rubbing. I would really like to feel like I can wheel my truck again without compressing the bejesus out of my current coilover. When I go out and wheel, I am like you, my better half, me, 2 dogs, cooler, and everything.
I have checked the King site, and they don't have the adjustable valving for the fronts that I have seen. I know they have it for the rears. I am ok with the stiffer ride that the 700# spring will provide. I am hoping it will help decrease the amount of preload that I need as well, since its so much stiffer.
12-14-2016, 10:27 PM
Real Name: Josh
Real Name: Josh
The 2.0's that I have only have a 550# spring. It needs to go up to at least 650, and if I am going to spend the money to up grade that spring. I might as well just buy new COs. My experience with Radflo has not been the best. The coils were a giant PITA to adjust from the beginning, the adjustment wrench I bought from them tore up the adjusting collars on top. They were good enough for what I needed before all the extra stuff, now they just aren't enough.
12-14-2016, 10:39 PM
well having 2.5 resi adjustable kings with 700lb springs fronts and 2.5 resi adjustable rears with ome 861.
felt like i need it all beefed up components with all the steel placed on the truck. i.e. shrockwork, cbi and budbuilts.
My rig is more of a expo rig, not quite crawler set up but it does really well. its awesome if your daily driving or driving hours 4+ to get to trails. It works great on trail and crawling,it pretty much out performs my willingness to push it that far both on speed and crawling since most trips are solo.
fronts mounted with access to the adjustors
rears compared to 5100. unit mounts so the adjustors are pretty easy to get to
2002 - trd s/c, header, exhaust, urd 7th...armored and expo set up
http://www.toyota-4runner.org/3rd-ge...ml#post2355344
1989 - 1UZ swap Cali Bar'd --SOLD--
http://www.toyota-4runner.org/classi...xperiment.html
12-14-2016, 10:42 PM
Real Name: Josh
Real Name: Josh
What part number are those coils? Are they actually the Taco coils that fit our rigs? How's the ride with the 700s?
12-14-2016, 10:46 PM
what headache are to talking for the resi? i to just installed icon 2.5 cdc ( adjustable dampening ) with 650lbs. I have full armor plus winch. Im not worried at all!
quick question, how do you measure your coilovers properly to know how much lift you have ?
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
12-14-2016, 10:51 PM
Real Name: Josh
Real Name: Josh
I measured my lift going from the ground to the center of the wheel well. The headache with the Resi I was talking about is the hose getting in the way sometimes.
12-15-2016, 09:08 AM
If you get the proper length hose or right shock made. You'll be fine. I just mounted my front coilovers with resi. And right away though, I noticed it will be impossible to do oil change because the resi blocks the oil filter lol!
I understand measuring from center hub to fender. But if I remember correctly you can measure the gal between the plate you twist and top of shock ? Just not 100%o
Actually just found a great video
https://m.youtube.com/watch?v=rKUUmbhUrpg
12-15-2016, 01:06 PM
Real Name: Josh
Real Name: Josh
I am guessing that the hose will be plenty long enough. So I'm guessing that's a non issue.
12-15-2016, 03:56 PM
@ jstim
, just give King a call and tell them you would like to add resis to a set of their Performance OEM coilovers and they should be able to take it from there.
What would need to happen would be they would have to send you a modified top cap or they could install it there at King before they leave if you haven't ordered any yet.
What I am getting at is that there probably isn't a part number for this listed on their sites.
'99 Millenium Silver Metallic | Factory E-locker | 5 speed | King 2.5 Coilovers | King Rear Shocks W/Resis | LC 7.5 Rear Springs | 231 Tundra upgrade | ES Steering Rack Bushings |
12-15-2016, 04:06 PM
Real Name: Josh
Real Name: Josh
Originally Posted by t4r92
@ jstim
I might just try that, see what they tell me.
