Old 02-20-2017, 07:45 PM #1
4flyer's Avatar
4flyer 4flyer is offline
4flyer is on a distinguished road
4flyer's Avatar
Power steering fluid level low. Do I use ATF or power steering fluid?
Was checking the fluid levels on my '01 today and noticed that the power steering fluid would not even register on the dip stick (I can visually see fluid in the reservoir though). The manual says to add ATF but it is the power steering fluid reservoir. What do I put in there? I am pretty new to maintaining vehicles. Anything special I have to put in there? Any special procedures or anything?
2001 Limited 4x4 Black/Tan
4flyer is offline   Reply With QuoteReply With Quote
Old 02-20-2017, 07:46 PM #2
Brian3676 Brian3676 is offline
Brian3676 will become famous soon enough
DexIII ATF is what you want
Brian3676 is offline   Reply With QuoteReply With Quote
Old 02-20-2017, 07:51 PM #3
ZionXIX's Avatar
ZionXIX ZionXIX is offline
ZionXIX is on a distinguished road
ZionXIX's Avatar
What do you do if the previous owner was putting power steering fluid instead of ATF fluid in the reservoir? How would you tell the difference? Also since its the PS system and not the transmission, is the cheap stuff adequate?
Sorry, read your post OP and suddenly had several questions come to mind.
__________________________________________________ ________________________
"Island Paradise" 1996 Toyota 4Runner SR5 2WD 235 75r15
ZionXIX is offline   Reply With QuoteReply With Quote
Old 02-20-2017, 07:56 PM #4
4flyer's Avatar
4flyer's Avatar
Recommend a brand? I just texted the previous owner to see what he used (if he knows).
Old 02-20-2017, 08:00 PM #5
reelamin's Avatar
reelamin reelamin is offline
reelamin is on a distinguished road
reelamin's Avatar
I use the Valvoline max life in the 4qt wal mart jugs. Perfect refill level for a tranny pan drain....pull out the old in the reservoir...refill with new. Do that several times the first year....bam its replaced and your good for another 100k.
He who Shi% fast does not Shi% for long!!
BILSTEIN CUSTOMER SERVICE SUCKS MUNG COVERED BALLS!!!
reelamin is offline   Reply With QuoteReply With Quote
Old 02-20-2017, 08:06 PM #6
johnbyebye johnbyebye is offline
Real Name: Scott
johnbyebye is on a distinguished road
Real Name: Scott
I'm actually wondering this too. It looks the PO of my 4Runner had the system worked on at one point since the fluid has been changed over to power steering. It's not a mix of the two and it's transparent with a slight yellow tint.
I've just left it alone with no issues but, I'm wondering if it's better to replace it with atf?
K82 2000 Limited T4R 4WD V6 auto, factory e-locker, BFG KO2s, Bilstein 5100's all around + 99 talls.
johnbyebye is offline   Reply With QuoteReply With Quote
Old 02-20-2017, 08:20 PM #7
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
There are probably thousands of 4runners and tacoma out there with power steering fluid instead of atf. It does not seem to harm anything right away, but if toyota wants you to put atf in then do it! If you are concerned at all that it is compromised just flush out the system and replace with new atf. Siphon out the old stuff in the reservoir, fill it up with fresh atf, remove the return line and then cycle the steering from one side to the other till it comes out clean. There are some good write ups on this if you search
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 02-20-2017, 08:58 PM #8
4flyer's Avatar
4flyer's Avatar
UPDATE: Talked to the previous owner and he never touched the PS fluid. Knowing that the first owner only had the 4runner dealer serviced, I am going to just top it off with Toyota Dex III and then monitor for leaks.
Old 02-20-2017, 09:01 PM #9
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Though ATF and PSF in general are similar fluids, ATF has much more stringent requirements. It is a higher quality lubricant in general. PSF would probably "work" but i wouldn't use it for sure.
x2 on Valvoline Maxlife ATF for the power steering system.
JZiggy is offline   Reply With QuoteReply With Quote
Old 02-20-2017, 09:11 PM #10
Real Name: Scott
Real Name: Scott
Next weekend's to do list: Replace ps fluid with atf.
Old 02-20-2017, 10:24 PM #11
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
In the past, I've read many anecdotes on forums for older Toyota trucks and Land Cruisers that reported problems with P/S pumps that coincided with P/S fluid being substituted for the the required Dexron ATF.
Replacing the fluid is easy.
If you don't know it's history, why not start your ownership with fluids that you know the origin of?
I used the currently available product which is sold as "Dex Merc" under Valvoline and and other brands.
pluton is offline   Reply With QuoteReply With Quote
Old 02-20-2017, 10:35 PM #12
4flyer's Avatar
4flyer's Avatar
Good point. While talking to the previous owner, he said that he never touched the PSF. He does know the original owner and he always got the 4Runner serviced at the dealer. Knowing that, I think I am just going to top it off with Toyota DexIII ATF. But knowing that the fluid is probably 10-15 years old, I think I will just replace it in the near future.
Old 02-20-2017, 10:38 PM #13
Frdmskr Frdmskr is offline
Frdmskr is on a distinguished road
Bigger question is, where'd it go? Once topped off make sure it doesn't slowly disappear. May have more work to do then.
Dan
1996 Toyota Rav4 (SCRAPPED), 199? Olds Alero GLS (SOLD), 2006 Volvo S60 2.5T AWD, 2001 Ford Escape XLT V6 (SOLD), 2001 Toyota 4Runner SR5
Frdmskr is offline   Reply With QuoteReply With Quote
Old 02-20-2017, 11:45 PM #14
MandAtaco's Avatar
MandAtaco MandAtaco is offline
MandAtaco is on a distinguished road
MandAtaco's Avatar
I use Valvoline Maxlife ATF in mine. Thats what Toyota recommends so thats what I run. I'm pretty OCD like that.
I know the old fords required ATF too, PS fluid would make the pump make a ton of noise.
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
MandAtaco is offline   Reply With QuoteReply With Quote
Old 02-21-2017, 12:00 AM #15
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
Max -life ATF. And, as others have stated, just flush it. It's an easy job, takes 30-45 minutes start to finish. Raise the front wheels, remove low pressure return side hose and put it in a catch bottle, plug the return nipple on the reservoir, and then cycle the steering wheel slowly lock to lock (engine off) while keeping the reservoir topped off with new ATF. When fresh ATF comes out of the low pressure hose (will take almost 2 quarts), you have flushed out the bad stuff and you're almost finished. Button everything back up, put truck back on the ground, top off fluid to correct level.
BrianK14 is offline   Reply With QuoteReply With Quote
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
Power Steering Fluid Level Question… swampy_swimmer 3rd gen T4Rs 3 05-05-2014 04:28 PM
Low Power Steering Fluid sct6239 4th Gen T4Rs 5 02-02-2012 03:50 PM
Power steering fluid dmanla Maintenance/Detailing 2 08-22-2008 05:39 AM
Which power steering fluid? Gryphon Classic T4Rs 2 12-04-2004 11:29 PM
