07-17-2017, 12:10 PM
Rear suspension setup for towing.
My 97 limited, has stock shocks, stock springs and 3 inch lift spacer. Works great, except when I hook up my trailer. I immediately get some noticeable sag. at least 2 inches. I've been searching the forum for information, and do not have any definite part numbers, or real payload information.
I've read home about FJ80 Springs, FJC springs... Even read about some highlander springs, but not a solid part number, and no real discussion of payload handling.
The trailer is a single axle, 6x10 wood floor trailer. Just basic.
I do not offroad much, maybe a little going to the deer camp and needed clearance more than anything else.
What would be your suggestions for replacement springs and shock for holding my rear end up with a load on.
Thank you in advance.
97 Limited 4Runner Dessert Dune Limited.
07-17-2017, 12:22 PM
I would get a set of OME 906's, you'll get about 2 inches of lift and they are awesome springs for towing. Ride is a little firm at first but they loosen up with time.
They are about 165 bucks shipped.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
07-17-2017, 12:44 PM
Thank you, fellow Wisconsinite. (I have been transplanted, but it never leaves you) I'll look into that. I would need to total 3 inches to level the truck, as I have 3 on the front. Is there a model that is an inch taller?
Heck, My 4runner has 240K miles, and I'm sure they are original springs.. I my just need new spring, to go with my current spacer.
I did find the LC spring sticky, Great right up. I didn't find much in the way of load ratings.
07-17-2017, 12:50 PM
Yes, OME makes taller springs than the 906. I can't remember which one it is but go to wheelers off road or the OME site and you should be able to find it.
Wisconsin > the rest =)
2011 Camry SE V6
07-17-2017, 12:53 PM
Thanks.
Yes, it is... I miss it sometimes. Then I go home in January and remember why I live in Arkansas... lol.
Remember Drink Wisconsinably..
07-17-2017, 12:56 PM
Real Name: Kyle
Real Name: Kyle
OME 2896s
OOOOOOOOHHHH heeeeey theeerrreeeee!
Fellow WI transplant here! GO PACK GO! I have a 5th gen with the OME 2896s 3" lift without a rear bumper. Stiff with no load and softer than fresh fallen WI snow with a load. And honestly, 50 lbs is enough to give it some softness.
Also, the stiffness is only noticeable because the 5th gen has such a soft stock suspension. I'm also running King 2.5" shocks with remote reservoirs.
If you order some suspension parts I highly recommend @totalautomotiveperformance. Zero tax and zero shipping.
Happy trails!
07-17-2017, 01:14 PM
Real Name: Neil
Real Name: Neil
I believe the 891 is the 3" lift coil for extra weight
2000 4Runner SR5 Black Sport 4wd V6 Auto
07-17-2017, 01:16 PM
Happy trails!
Thanks Deepsea88,
I just found some OME 2891 springs on Wheeler's, that might do the trick, like Door County Wine, doocha know. I do have a 2x10 box, and a stock bumper so Should be enough to soften the 2891's ride...
I might just get a set of MOOG Replacements, If I can findout what The difference between Standard and professional are.. I'm feeling like my 240K stock springs are just getting tired.
I might even be on a unicorn hunt right now. I want stock ride, 3 inches of lift, and an extra 500lbs of towing...
07-17-2017, 01:28 PM
I am also in the pricess of getting new springs / shocks. I read that MOGG springs may give lift, but sag a lot and quickly, with any load.
I tow sometines, my springs actually dont sag to bad as is, but I am lookibg at the 906 for the smaller lift.
SOLD. 1997 SR5 auto w/ factory E Locker - purchased June 2017, tranny cooler, 60A Blue Sea Fusebox, deck plate mod, rear heat delete, 99+ headlight swap, 99+ console/cup holder, PIAA Fog Lights 55W, LED dome/map/reverse lights, Firestone Air Lift, KYB shocks/struts,MOOG front springs, OME 906 rear springs, 265/75/16 E Duratracs, Tundra Sport Rims, Kenwood KDCX700, pioneer 2 way front speakers, Rear Diff Breather EXT
2012 SR5 - tranny cooler, Bilstein 4600's, OEM Trail wheels, 1.5" wheel spacers, Duratracs
07-17-2017, 01:29 PM
Thanks SOFloT4r.. Greatly appreciated..
07-17-2017, 01:37 PM
Thanks Yella.. I believe we are both chasing the same dog. I have to tow sometimes, and I am leaning towards 240K miles, and 20 years OEM (Not OME) springs may just need some newer ones..
Anyone went with the LC-7 coil on the 4runner, and have some input on sag during towing?
I still researching and The more I search the interwebs I get more questions.
I'm guessing the OME 2891s are constant rate springs? And would variable rate be better. I could be completely wrong on all of this.. If I read correctly the Constant rate Springs would give less sag under load than variable.
07-17-2017, 01:45 PM
Since you like the unloaded height and performance of your current suspension, why not just get some in-spring airbags (airlift or similar). Run them at minimum pressure for daily driving and put in whatever you need when towing.
Otherwise, the 906's will be the 'best' for mild lift and towing (highest spring rate), but other OME springs are available for more lift. No matter what, the springs will compress a bit when loaded...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
07-17-2017, 02:08 PM
Ok, so called my buddy at the Toyota parts shop. We discussed several question's I had.
He said Bags would be ideal, but he agreed that my OEM springs are probably tired. He recommended replacing the stock springs with some professional grade variable rate AC Delco springs from Rock Auto. said they have a 780LBS rating, that is substantially more than OEM, see how it works and if it sags under load add bags.
This sounds quite a bit like a viable option because of the cost of the OME shocks vs. the AC Delcos at Rock auto. I'd be in to $80 vs $180. and I can use the spacers I have to set the ride height. I would know it wasn't wore out springs..
Thoughts?
I appreciate the input from everyone.
07-17-2017, 02:14 PM
Not sure about the AC delco springs but most of the "cheap" aftermarket springs do not last very long. Some people have had good results with Moog but many others have not.
If the AC delcos only last a couple years before sagging again, was the 100 bucks savings worth it? That's up to you.
OEM/OME or some of the other quality springs will last much longer. Those springs are $80 a set for a reason. OME is a nice compromise of good quality but not super expensive (cheaper than OEM I think).
If you plan on keeping your truck for awhile, spend the money and get a quality set of springs. Buy once, cry once....
P.S. When I hook up my #2500 boat/trailer on my rig with 906's, it barely lowers at all. The ride quality of the 906's while towing is excellent! I also keep a bunch of stuff in the back (tools, sub, etc).
2011 Camry SE V6
07-17-2017, 02:27 PM
Thanks, Charlie.
It looks like the 906 (I'm actually seeing P/N 2906 on Wheeler's sight) gives about 2in lift and a 230 load rate, I have 3in on the front. the OME 2891 give about 2.5 to 3 and have a 210 load rate. They would seem comparable in all aspects except lift, where the 2891 would give more.
Hope this helps explain my understanding of the part numbers.. I am always willing to listen to others, and there is a chance I'm wrong.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
