Old 08-20-2017, 09:06 PM #1
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
theesotericone's Trails and BS Thread
This will be the place to see what trails my rig has been doing lately. It will also be a place to just shoot the shit. Got something to say? Say it. I'm not easy to offend and a lot of you guys are actually enjoyable to chat with. Which is saying a lot since I don't like most folks. lol
I started building my rig about 14 months ago. There was a plan for it since day one. That plan was a simple one. To make it capable of taking me where I wanted to go and also be able to get me home. This rig also does double duty as my wives daily so I had to keep it completely road worthy as well.
I'm horrible about taking photo's so I never went the build thread route. Instead I put my content all over the "What did you do in" thread. For those of you wanting to see some of the mods that got done search my username in that thread.
Thanks for stopping by.
The Rig
1997 SR5 4X4 Auto
Lift
Eibach #620 lb Springs w/ Taco Billies 2nd Perch Front
ARB OME 2861's w/Toytec Boss Shocks Rear
SPC Upper Control Arms
Extended SS Brake Lines F/R
Extended Rear Sway Bar Links
Front Sway Bar Removed
Drive Line
ARB Lockers F/R
5.29 gears
MB Motoring 352's 17x9 -12 Offset
Nitto Ridge Grappler 295/70/r17
1.25" Hub-Centric Wheel Spacers
231mm Power Stop KC2324 TBU
Armor
Relentless Fab Predator Front Bumper
Savage Off-Road Dual Swing Out Rear Bumper w/ Tire Carrier, Hi-lift Mount(soon), Rotopax mounts
Savage Off-Road Skids
Stubbs HD-SKO Sliders
Rola Roof Rack w/Custom Low Pro Mounts
Recovery
Engo 12000lb Winch Synthetic w/Wireless
48" Hi-lift
MAXSA Traction Boards
4 Gallon Rotopax Gas
2 Thirty Foot 20000lb Straps
Tools to Fix Shit On The Trail
ARB CKMA12 Mounted Under Hood
Electrical
All Grounds Over-Sized
100A Relay Wired to Ignition
100A Bussman Circuit Breaker
12 Gang w/Negative Blue Sea Fuse Box
5 40A Relays w/Custom Acrylic Mount
Blue Sea 9003E 350A Battery Disconnect(for winch)
Custom Acrylic Rocker Switch Dash Insert
2 Seven Inch Combo LED's Top of Bumper
2 Four Inch Spot LED's in Bumper
SNAN 300W Inverter
7" Electric Trans Cooler Fan
Music
Butyl and Mat Sound Deadening 75% of Rig
Pioneer TS-W259S4 Champion Series 10" Single 4ohm 1200 Watts Mounter in Rear Storage Compartment
Polk DB651's 6.5" in Rear Door
Infinity Reference 6500CX 6-1/2" w/Tweeters in Front Door
Boss AR1500M ARMOR 1500W Mono for Sub Mounted in Rear Quarter Panel Behind Sub
Hifonics ZRX1016.4 Zeus 1000W 4-Channel for 6.5" Under Drivers Seat
Dual DV526BT Double-DIN DVD Receiver
If It's To Loud Your To Old
Other Mods
Hayden Trans Cooler In-Line w/ New Rad
Auto-Meter Trans Temp Gauge w/Pillar Mount
Sonora Steel Rear Poly Body Mounts
Sonora Steel Washer Bottle Relocate
Rear Diff Breather
Front Diff Breather
June 9th 2016
Current
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 08-20-2017, 09:29 PM #2
Sand Canyon and Wheeler Ridge
Finally my rigs pretty much where I wanted it. There will be F/R lockers and a re-gear coming in the next year but for now I'm happy to be wheeling it instead of working on it.
Here's a little trail I went out on today. It's called the Sand Canyon Trail. It starts in the community of Swall Meadows just north of Bishop. It's an out and back trail that's about 12 miles each way and ends at the wilderness boundary in Rock Creek.
There's also a spur road here called the Wheeler Ridge Trail. That takes you through some gnarly terrain. Did I run it? Of course I did.
As soon as you start the trail you're greeted with a "Most Difficult" sign. About 100 yards after that it turns sharp uphill and you hit about 7 obstacles. Big rocks with only a few good lines is what this trail is all about. There spread over about 1.5 miles so you have some time to chill in between the oh shit moments.
It's another 1.5 miles from the end of this section to the old mine. There's an overlook about 1 mile in that most people stop at. The road from there to the mine is super loose, off camber and scary as shit. I backed out about 1/4 mile. I stopped again at the overlook to rethink my plan.
My plan is now to do this section with another rig. There's no winch points anywhere on the way up and it's off camber and loose. There's actually a sign there that states not to take motorized vehicles up it. That means I have to do it. Who's in?
The Sand Canyon trail is passable by most stock vehicles with an experienced driver. The Wheeler Ridge trail is the real deal. Lift, 33's and lockers if you got them will all come in handy. A spotter's not a bad idea for those of you not used to going solo through Class IV.
theesotericone's Trails and BS Thread-img_20170820_121351-jpg  theesotericone's Trails and BS Thread-img_20170820_124203-jpg  theesotericone's Trails and BS Thread-img_20170820_131656-jpg  theesotericone's Trails and BS Thread-img_20170820_141743-jpg  theesotericone's Trails and BS Thread-img_20170820_142210-jpg  theesotericone's Trails and BS Thread-img_20170820_145839-jpg  theesotericone's Trails and BS Thread-img_20170820_150002-jpg
Old 08-20-2017, 09:35 PM #3
While filling my tires back up I did the usual rig inspection. I found this little guy that didn't quite look right. Energy Suspensions. Any one else have one of these brake like that? I might go back to OEM. Rubbers a little more forgiving when it's stressed. At least it's an easy fix.
theesotericone's Trails and BS Thread-img_20170820_162204-jpg  theesotericone's Trails and BS Thread-img_20170820_162237-jpg
Old 08-20-2017, 10:58 PM #4
AssBurns's Avatar
AssBurns AssBurns is offline
Real Name: Steven
AssBurns will become famous soon enough
AssBurns's Avatar
Real Name: Steven
About time! I haven’t seen any photos of your rig yet. Looks awesome! Maybe one of these days I’ll cruise up and we can do a wheeling/ camping trip. Also I saw that Dirtco had the same issue with his rack bushing. I bought some like 6 months ago, but haven’t installed yet. Maybe I’ll hold off then.
The BeerRunner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
AssBurns is offline   Reply With QuoteReply With Quote
Old 08-20-2017, 11:14 PM #5
85straight's Avatar
85straight 85straight is offline
Real Name: Al
85straight is on a distinguished road
85straight's Avatar
Real Name: Al
Nice photos! I've always wondered if there was a trail that lead up the pass, looks like a blast.
Mall Rated
'85 dlx- diy sliders, Addicted Off-road rear bumper, Spooled rear, OME rear springs, pro comp fronts, Killer Toy Tops bikini top, 33s
85straight is offline   Reply With QuoteReply With Quote
Old 08-20-2017, 11:16 PM #6
Road Bull's Avatar
Road Bull Road Bull is offline
Real Name: Ryder
Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough
Road Bull's Avatar
Real Name: Ryder
Awesome! Glad to see you started your own page man. I know you don't dig taking lots of pics, but you have got some cool mods that I am sure people around here are happy to check out. That rear bumper looks like it came together well. And it's cool to see your rig stretching its legs out on the trail.
2002 SR-5 in Millennium Silver.
Timeline>> http://www.toyota-4runner.org/3rd-ge...-timeline.html DEAD
2002 SR5 Changeling Build https://www.toyota-4runner.org/3rd-g...ing-build.html
Road Bull is offline   Reply With QuoteReply With Quote
Old 08-20-2017, 11:18 PM #7
There's photo's of my rig all over this site. lol I finally just decided to put them in one place.
It's funny your the first one to post. I almost mentioned you when I typed the "Who's in?" line above. I figured you'd be down judging my some of your posts on here. As far as I know the road to the mine is the highest 4x4 road in Cali. I was probably still 400' shy of the top when I chickened out. That was at 11,000 feet.
I might have kept going but had a strange encounter with a guy I know at the end of the Sand Canyon trail. He's came up to the parking area on his enduro. We said hi and chatted for a bit. I told him I was planning on doing the old mine road. He looked at me and mentioned it was pretty crazy. Then he told me about a Toyota that rolled when the road broke out a few years ago. I said bye and headed up.
As soon as I realized how shitty the road was that last 1/2 mile I backed out. Why? Because I was in a Toyota. Had he said it was a Jeep that rolled I probably would have kept going. With another rig behind you or in front of you to winch off of if you slide out I think it's doable. Sketchy but doable.
I've wheeled pretty hard on those bushings for 9 months now. Honestly though, this trail was the hardest I've done. I'm really surprised that was the only damage. I fully expected to snap a CV axle. It's so tight at times you have to power through while still under full lock full stuff. I sure fire way to snap CV's like toothpicks. I'm impressed my rig made it without a rear locker.
Originally Posted by Road Bull View Post
Awesome! Glad to see you started your own page man. I know you don't dig taking lots of pics, but you have dine some cool mods that I am sure people around here are happy to check out. That rear bumper looks like it came together well. And it's cool to see your rig stretching its legs out on the trail.
Thanks man. I might organize some stuff and put it here but this will mainly be wheeling thread. I'll add a photo of my rig and a list of mods to the OP eventually. I'll also find a photo hosting site so you guys can blow up the photo's. The only downside to using the attachment function on the site is you can't blow them up. That and you can't add text between them. Blowing up some of those photo's gives you some cool stuff your not seeing all that well with the attachments. For instance, there's a most difficult sign off to the right of my rig in one of the pics. It looks great blown up on my comp but is hardly noticeable in the post.
As far as the bumper goes, I'm incredibly happy with it. It took a beating today. So did the skids and sliders. That trail isn't very scenic by Sierra standards but it's a beast by wheeling standards. Everything is still attached to my rig and functioning well, except that bushing. lol
Old 08-20-2017, 11:54 PM #8
AssBurns's Avatar
Real Name: Steven
AssBurns's Avatar
Real Name: Steven
That’s funny that you almost mentioned me. How late in the season is that trail passable? Sounds fun! I’d like to check that one out and maybe camp. I’m busy most of next month but if it’s doable in October, I’d be down to drive up and check it out for the weekend or at least an overnighter.
I’ve never had any major issues like that with my rack bushings. Even with all the wheeling I do. I might try the Energy bushings out just to see for myself. If they turn to shit, I’ll swap them back out. As for breaking CV’s, they only break when your doing stupid shit. I’ve only broken one so far and I knew it was going to happen too. Since then, I knew the limits of what it takes to break CV axles. I don’t get how people break them all the time. Wheel smarter not harder haha.
Old 08-21-2017, 12:01 AM #9
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I was in the Rock Creek area a couple weeks ago and didn't even realize there was a trail that ran parallel to the paved road going up to Rock Creek Lake! We were in my buddies company car this trip so no off road trails for us this time around.
On another note, I finally got my Sierra Slam up in Little Lakes Valley! Goldens at Treasure, more Brookies than I remember at one of the Gem Lakes, and Rainbows & Browns in Rock Creek near our campsite in East Fork. There was a lot of water running through there this year so the creek fishing took a bit more finesse to be successful this trip. Saw a hybrid Brookie/ Rainbow in one of the Hidden Lakes, which was pretty cool too. Common in any of the lakes you fish around Bishop/ Mammoth? Ooh, also stopped by Hing's Donut shop in town. They have a killer breakfast croissant sandwich with jalapeño!
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 01:08 AM #10
It'll be passable till the first big storm drops more then 12" of snow on it. Could be Oct could be Nov. I'll keep it in mind if you wanna come up and get out for a weekend in Oct.
Next time bring your rig up and camp at the end of Sand Canyon. It ends about a half mile from Dorothy Lake. Then Tamarack is another 2.5 miles past Dorothy. It's easy to pick up the trail and it skips about 1500' of elevation gain compared to coming in from the Rock Creek side. When your done fishing those head back to Hings and get some donuts. Now point it towards Coyote Flat and go to Baker Lake. Enjoy the tips. There good ones.
I've never seen or even heard of a Brookie/Bow hybrid. There's tons of Cutbows and Golden/Bow hybrids but the Brook/Bow is a new one to me. Did you actually catch it or just see it swimming by? I'd be really curious to see a photo of it. How big was it? It could have been a Cuttie. Small Cutties can look very similar to what I imagine a Brook/Bow cross to look like:
Old 08-21-2017, 01:56 AM #11
Real Name: Evan
Real Name: Evan
Yeah, I'm probably making a bad ID and it's something different. My go-to website for the Eastern sierras is Stevenojai.tripod.com and I read there was only Brook and Rainbows in Hidden Lakes. Here's a link to the area that I read up on what Lakes have what fish in them.
http://stevenojai.tripod.com/http://...m/rcreekbc.htm
Here's the one I took a photo of. What do you make of it? I just looked at some more online photos and it almost has the big oval spots that Goldens have. I just assumed it was a hybrid Brook/Rainbow based off of the fish I thought were in there.
theesotericone's Trails and BS Thread-img_7793-jpg
Old 08-21-2017, 02:09 AM #12
That's a juvenile Brookie. The parr marks will go away once it gets bigger.
Fish Details
Old 08-21-2017, 02:45 AM #13
Real Name: Evan
Real Name: Evan
I just searched juvenile rainbow and they also have the parr marks. Seems like both species as juveniles are very close in apprearance.
Old 08-21-2017, 03:12 AM #14
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Subscribed!
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 08-21-2017, 12:26 PM #15
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
It's about time! I don't think I've seen but one picture of your rig, but I also don't frequent the What did you do today thread.
Looking forward to see where all the rig will take you! It's fun just taking the truck out and wheeling it/exploring and not trying to build it at the same time. So far for me it's been mostly maintenance and a few small mods here and there but a lot more trips this past year.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Early 5th gen trails vs new 14-15 trails? wheelds 5th gen T4Rs 45 03-22-2021 09:59 AM
Good Fire Trails or Logging Trails Out West? bradentyrer Off Topic 0 01-29-2013 11:07 PM
USA trails Edubsam General Discussions 1 07-20-2011 10:18 PM
Trails You Have Run glenyoshida 3rd gen T4Rs 24 01-12-2011 04:58 PM
Trails in VA NDRYDEN123 General Discussions 1 08-27-2008 11:13 PM
