instrument panel dimmer replacement?
triangles
I was replacing some dash lights and busted my instrument panel dimmer trying to get the damned plug out of the back of it when I was taking things apart. Does anyone know where I can get a replacement or a part number I can search? all i seem to find is the headlight stalk when I search for the dimmer. Oddly Rock Auto thinks the stalk is a dimmer switch as does other auto part places...
It's called a rheostat switch, that should wield better search results.
Junkyards are great for these sorts of parts too.
are you talking about this?...
i have a bunch of these for some reason.... if you can't find one i can send you one.
Junkyard, look for any Toyota with a dimmer knob that looks the same, found mine out of a similar era Camry. You know, what ^they said. :)
