Originally Posted by CalBlackSheep
Is there an easy way to check for bushing failure or should I just take it back to the alignment shop?
Thanks for the help
The fact you need to ask these questions makes me think you should take it to someone, but there
are things you could look at. First thing is have some one help you measure the wheelbase, center of wheel to center of wheel on each side. If there is a 1" difference, that is a big problem. If there isn't more than an 1/8" or so, your trouble is elsewhere. Second, remove any shields under the front, lie underneath while someone turns the steering back and forth from lock to lock. Look for movement of the lower arms/bushings. The uppers are harder to see, but you can look over the tire, or jack it up some.
