12-06-2017, 11:20 PM
Backup camera install question
Just installed my new pioneer avh4201nex. Now I am doing the backup camera with it, question I have is which wire should I tap it into to? I am looking for constant power. Which wire would be the best? Anyone out there done a backup camera? I just want to select the correct wire.
I understand doing the reverse tailight is probably the easiest but I want constant power so it can be turned on whenever.
12-06-2017, 11:44 PM
Run a T tap into your deck power wire and hook it up through that. Then run a purple wire from what I believe is a purple wire from the deck and T tap it into your reverse light wire. I did this and ran all the wires for my camera down the drivers side
2000 millennium silver limited, TRD 1st gen supercharger, Toytec/eibach 3"springs, Tundra 5100's,LC 8 wraps w/ bilstein 5125's, 285/70/17 toyo mt's on FN FX Pro in matte bronze
2015 Harley FXDB 103, cams, thrashin supply pipe, vance and hines tuner, LED lights all around
1st gen, 4 inch lift, 35/12.50/15 goodyear MT/R, GONE
My build http://www.toyota-4runner.org/3rd-ge...ml#post2828875
12-06-2017, 11:55 PM
Instead of hooking up to back up light. Run that wire to a fused switch on dash. Tap into acc. Fuse for power. Switch on. ..cam on switch off cam off. Good luck.
12-06-2017, 11:57 PM
I'm about to hook up my backup camera soon as well but if I only want the camera to turn on in reserve where do I find the wire that activates the reserve lights?
12-06-2017, 11:59 PM
The wire coming out of the reverse light itself.
12-07-2017, 12:15 AM
If you want your back up camera to turn on when you back up..... you would tap into your back up light wire like I stated above. The Pioneer deck has an option to press the camera icon in the drop down menu for camera on whenever.
12-07-2017, 12:44 AM
I don't know anything about the pioneer deck. The last part of his question, asks for constant power. I tried to answer. Why are you busting my lug nuts?
12-07-2017, 01:13 AM
Constant power would be when your vehicle is on. Which T tapping into you power from the deck would do. I wasn't trying to bust your balls. I just did this exact same installation a few weeks ago on a pioneer AVH-4100nex which is the deck right before his deck. It was surprisingly simple to hook up. The biggest pain in the ass was running the wires
12-09-2017, 11:11 PM
Real Name: j
Real Name: j
Which back up cameras are members using?
12-10-2017, 01:27 AM
Real Name: Grant
Real Name: Grant
Backup camera
I got a $20 rear license plate mount camera from Amazon. Pretty sure it is a Pyle brand one. It works decent, was able to aim in properly and the guidelines aren’t awful. I cut the reverse wire on the driver’s side, and soldered in a patch cable. Connected the patch cable to the positive lead on the backup cam, the jumper wire for changing the input on the NEX, and another jumper wire to hook back in to the factory reverse wire for the light. Heat shrink wrapped everything, and it has been working great. Just my two cents.
04-27-2020, 08:10 PM
Real Name: Jake
Real Name: Jake
For the reverse wire that goes to the deck, I used the red/yellow stripe wire that runs from the junction block to the reverse lamp. When you pull up the kick pa el by the drivers left foot there is a large cam lock connector and the wire is easily accessible on the top of it.
I just used my volt meter to verify it switched power when shifting to reverse.
04-27-2020, 08:22 PM
I believe that's the same one I used, you can always crimp the wire back together if its the wrong one.
Sent from my SM-N975U using Tapatalk
work in progress
04-28-2020, 12:13 AM
OP mentioned constant power to the camera. Not all cameras are 100% duty cycle. Meaning not designed to run all the time.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
04-28-2020, 03:07 AM
Couple of things. As 503 mentions Pioneer decks have the option of turning the camera on while in drive or whenever. It comes in handy, especially if you are moving stuff and can't see your trailer very well.
It's a PITA, but you can run the wires up to the top of the rear hatch and out through the factory grommet/sleeve. The RCA connectors can be shaved smooth with an exacto and some dish soap really helps get them through. Be very careful tugging on the middle prong of these cheap chinese RCA connectors, they fall apart easily.
One of the best spots is in the tag trim piece opposite of the key slot. Looks symmetrical and OEM.
When you go to replace the camera, it should be as easy as removing the back trim and quickly swapping out just the camera.
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
09-10-2024, 01:55 PM
I have a pioneer and I have the camera to install it and unless I'm missing something, why can't the 12V power be wired into something that's just always on like the car's main power wire? I want the ability to use it without reverse also and my deck has a camera button. I like the idea of the fused switch idea listed above but why a switch? Is it bad to just have it always being on?
