Old 09-10-2024, 07:57 PM #16
Originally Posted by mendozer View Post
I have a pioneer and I have the camera to install it and unless I'm missing something, why can't the 12V power be wired into something that's just always on like the car's main power wire? I want the ability to use it without reverse also and my deck has a camera button. I like the idea of the fused switch idea listed above but why a switch? Is it bad to just have it always being on?
You can do that no problem. You will still want to hook up the reverse light power to the reverse camera trigger (which is then separate from camera power which should be any switched power). That's how I have mine setup - both front and rear cameras are available anytime the radio is on.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-11-2024, 02:29 AM #17
mendozer mendozer is offline
mendozer is on a distinguished road
you lost me on that. the camera has an RCA for the head unit and a black/white power wire plug/wire pair. I was thinking that since I have to run the RCA all the way to the head unit, and it's powered by the ignition, why not run that power cable (red i assume) to the head unit's power cable? it would be on whenever the head units on. Black i assume would be to the cars negative or ground.
i don't know what you mean by trigger wire
mendozer is offline   Reply With QuoteReply With Quote
Old 09-11-2024, 09:21 AM #18
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 will become famous soon enough
Robb235's Avatar
Real Name: Robert
I don't know what the typical life of the camera is, but having it on all the time will certainly make it shorter.
Use a diode so that you can have two inputs (reverse signal or brake lights, power from head unit whenever you want your rear camera on) to keep the input signals separated from each other. Otherwise, when you're driving along and you decide to view your camera to see what's behind you, you'll activate your reverse lights as your moving forward. Will confuse other drivers on the road.
Diode: Amazon.com
Attached is a wiring diagram I made up when I wired my backup camera. My particular head unit didn't have the option to turn on rear camera on demand, but did have a front camera on demand option. I used a splitter so that my rear camera fed both the front and rear camera ports on my head unit.
Backup camera install question-backup-camera-diagram-jpg
1999 Toyota 4Runner Limited 4x4 - Turbocharged GTX3071 - uaEFI Standalone ECU - DW255 fuel pump - 550cc fuel injectors - Rear Elocker Retrofit w/ 4.30 gears - 2wd Low (2Lo) On Demand - 231mm Tundra Brake Upgrade - Hayden 699 Transmission Cooler - Monitoring ATF Temps w/ My iPhone - DIY Projector Headlight Retrofit - Backup Camera Retrofit - 265/75/R16 Cooper Discoverer AT3 - OME 906 Rear Coils
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 09-11-2024, 12:23 PM #19
The head unit will have a trigger wire that lets it know the vehicle is in reverse. Camera has power/ground/RCA. Head unit has RCA and trigger wire. Connect the camera to switched power (that is on with the vehicle) and connect the head unit trigger wire to reverse lights to automatically switch to the rear camera signal when in reverse.
Old 09-13-2024, 01:31 AM #20
i think i understand. the trigger will kick on when in reverse. but when driving forward, i can manually tough the Pioneer's camera button to view as well. No need a special thing like a diode for that?
Old 09-13-2024, 01:32 AM #21
Diode: Amazon.com
Attachment 412836
I gotta study up on this lol. I havent wired anything since my car's remote start and that was 8 years ago.
Old 09-13-2024, 02:48 PM #22
My radio did not have a camera power out but I can select front or rear cameras as desired at anytime, along with automatic reverse camera triggering. This means no need for diodes or other trickery, in my case.
You have to figure out what your stereo is capable of and wire it according to that.
Old 09-14-2024, 01:50 PM #23
ok i think i got it. I looked up the Pioneer manual. I know which wire is the reverse trigger. It says to connect that to the voltage-changing wire from the tail light (i haven't looked yet but i assume that may be obvious)
Is this wiring diagram right? just splice in the red wire from the camera to the tail light, black to ground (probably leave it near the hatch door to not require a long wire run) then RCA in.
Backup camera install question-pxl_20240914_174759541-jpg
Old 09-16-2024, 02:00 PM #24
That will work to ONLY trigger the reverse camera in reverse (it will leave the camera unpowered if you try to view it when not in reverse). You can also find the reverse wire up under the dash - it is a red with yellow tracer wire. You can find it in/near the connector that connects to the harness that runs to the rear on the driver's side, and up in a junction connector behind the fuse box there (if you have an auto trans). Obviously check with a multimeter to make sure you have the correct wire before connecting the camera to it.
Old 09-17-2024, 01:25 AM #25
yeah i realized that after I hooked it up. That's fine, I've driven for 20 years without one so I only care about looking down at the bumper when backing into a tight space.
Old 09-17-2024, 12:56 PM #26
I've gotten too used to having one on so many other modern vehicles that I went back and added one. It is nice to be able to KNOW that there is nothing hidden back there below the rear window. Oh, and aligning trailers without opening the rear hatch for those rare times I tow...
Old 09-18-2024, 04:05 PM #27
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
It definitely makes backing up to a trailer much easier. Not as much hopping out and seeing how much further I need to back up. I've had trailer tires blow out before, so I like activating the backup camera as I'm towing down the highway to catch anything that might not look right.
Old 09-20-2024, 02:09 PM #28
after a week of use I'm actually not quite happy with it. It's not wide enough. I can tell what's 2' behind me at the very closest but it's not zoomed out enough. Could be because it's on the license plate vs above like on the top of the rear hatch. It's also from 2015 when I bought the runner so it might just be a crappy old camera style. It was just sitting in the shed all these years.
I'm debating getting a NATIKA style one and maybe mount it on the hatch top near the third brake light so I can look down at the bumper/hitch and see all the sides since it has a wider angle. I tested it out and I backed up today and purposely hit the curb with my tire but couldn't see the curb on the camera at all. so....darn.
Old 09-29-2024, 02:02 AM #29
I ended up getting the NATIKA style one, installed by the third brake light so it looks like an OEM mod, symmetrical to the rear windshield spray. I will say.....it was a HUGE PITA to do it that far out because my through-socket is only 5 inches long and you need to get the nut on the threaded bolt on that camera and there's no other way. and the wire got twisted up around the tool, must have taken me another 45 minutes just getting the tool back out. But wired it through one of the seep holes in the hatch shell and right down the rubber boot we're all familiar with. As a tip, I just slit the rubber boot and shoved the wire down real easy. Followed up with liquid electrical tape and regular tape so it's solid. image quality so much better and with that style, I can cut one of the installation wires so the image isn't reversed but rather straight on. I love it.
Backup camera install question-pxl_20240921_224339189-jpg  Backup camera install question-pxl_20240921_224320591-jpg
Backup Camera Install MNT4R 4th Gen T4Rs 15 02-23-2020 06:06 PM
My Backup Camera install ahhweewee Engines / Suspension / Wheels / Tires / Audio / Accessories 44 11-11-2019 07:35 PM
Backup Camera Install on a 3rd Gen 4RunnerRedondo 3rd gen T4Rs 3 07-24-2016 02:25 AM
Backup Camera Install Input? UT Hack 3rd gen T4Rs 5 07-17-2013 05:18 PM
Where to install a backup camera in a 2004 T4R? 4runner19 4th Gen T4Rs 3 01-05-2010 11:56 AM
